Author Topic: mfj 1763 3 el. 144mhz yagi  (Read 1422 times)
4X1KS
« on: May 25, 2016, 03:08:04 PM »
I am rebuilding this antenna due to corrosion and wear.  Inside the boom is a small trimmer capacitor which is used to adjust the antenna for best swr.  The cap in my old antenna is fairly corroded.  What do you this the value of this little ceramic trimmer is?  If I have one in my junk box then I can replace that cap and the antenna should be good.
Mark
