Author Topic: Repeater on-the-cheap suggestions??  (Read 10987 times)
KD2E
« on: December 19, 2016, 08:23:32 AM »
For a local Scout camp, I'm investigating the possibility of installing a ham repeater.
I know I could get a upper-end Motorola setup, or even a Yaesu/Kenwood unit (which may still happen!!!).
But, how can I do a work-able repeater on the cheap?
Can a pair of Beufeng mobile rigs work?
What would your suggestion be for faster/cheaper on-the-air?
I know I need radio, controller, duplexer, and antenna.
The antenna could be a ham Comet or Diamond. I guess the duplexer is where you don't want to skimp...to keep the transmitter
out of the cheap receiver.
Any thoughts?
If there is no cheap, workable solution....I'll re-think!!!
Thanks all!!
...Dave   KD2E
K1ZJH
« Reply #1 on: December 19, 2016, 02:18:23 PM »
Well, define cheap!!!  What is your price range?   Serious answers really depend upon the depth of the pockets involved.
Duplexer is the biggest expense, and the heart of the system.
Pete
N8EKT
« Reply #2 on: December 19, 2016, 03:15:40 PM »
Get a 440 repeater to keep your duplexer costs down
And you don't need much power
A 10 watt repeater will provide plenty of coverage
Kenwood tkr820 repeaters are on eBay at $250 or less
Used mobile duplexers are $150 or so
Or you could use two antennas vertically separated
Stay away from all the hamgrade antennas if yo want to avoid problems
The only ham grade antenna I've ever seen that was built well enough for repeater service is the Hustler G6-440 or the G6-144 for2 meters
ONAIR
« Reply #3 on: December 19, 2016, 03:47:09 PM »
Maybe 2 home brew ground planes?
K1ZJH
« Reply #4 on: December 20, 2016, 07:49:02 AM »
N8EKT gives good advice.  440 is much easier and cheaper!  And, you're more likely to find an open pair that can be coordinated.
Pete
W6SWO
« Reply #5 on: January 12, 2017, 01:09:49 PM »
What about using a radio with cross-band repeat capabilities like a Yaesu FT-8800/8900?  That would work for a demonstration.
N2DOW
« Reply #6 on: September 25, 2017, 01:47:38 AM »
A couple of Motorola maxtracs would be a cheap and reliable option as far as the radios. Repeater builder has tons of info on them. Just be aware of the rules. If it's a permanent setup it should be coordinated.
K4JJL
« Reply #7 on: September 25, 2017, 06:55:40 AM »
« Reply #8 on: September 25, 2017, 07:59:10 AM »
If the repeater situation in your area is anything like it is in my area, we have a repeater for each ham in the area.  Since each ham is monitoring his own repeater, no one ever talks to anyone.  All repeaters are dead 24/7 with absolutely no activity unless in the case of severe weather , and then everyone is on the weather repeater.  Do you really need your own repeater?  Isn't there at least a dozen unused repeaters you can access from your area of interest?  "What we have here is a failure to communicate"..  So says the warden in "cool hand luke".
If you really have no repeater coverage, then by all means disregard what I just said. But I just hate the fact that we have a repeater on every frequency now, and they are all useless. "back in the day" we had a couple, and they were in use 24/7, and it was a much happier situation.
N2DOW
« Reply #9 on: September 25, 2017, 08:17:38 AM »
I guess I wasn't paying much attention to the dates considering this thread was at the top of page 2..
I agree, if there is already a repeater available in the area use it. Someone has put a lot of time and effort into it.
Chances are this guy has already written off the idea anyway.  Cheesy
KI6HLD
« Reply #10 on: March 20, 2018, 02:39:31 AM »
That's the cheapest.  Having two vehicles with those mounted is easiest.
Our club set up an emergency repeater as a test, using two FT-8800s.  Set crossband repeat on each one, with the crossband frequency an unused frequency in the UHF band.  One set up to receive VHF, transmit UHF at very low power, the other to receive the UHF and transmit VHF at intermediate power (20W on the 8800).  The separation of the two units needs to be at least 80 feet, with more separation better to keep from desensing the VHF receiver.  You generally would not use the full power for the VHF transmitter as most of this type radio are not rated for 80% or more duty cycle.  Lower power keeps them from overheating.  As a demo or an emergency this is the simplest setup.
