Author Topic: FT991 won't transmit on 60 meters  (Read 3321 times)
KK6RPX
« on: January 31, 2017, 09:49:08 PM »
Hi All,
Sorry if this is in the wrong place. Wasn't quite sure where to post.
My FT991 won't tune or transmit on 60 meters. I've looked through the manual and whatnot and don't see why this is so. The rig just beeps and refuse to transmit, although I can copy signal fine. There must be some setting or some darn thing but I can't seem to find it.
AC5UP
« Reply #1 on: January 31, 2017, 10:59:35 PM »
http://universal-radio.com/catalog/hamhf/3991_60m.html
Have you considered how many wireless devices are in simultaneous use near PyeongChang, South Korea?  The TV coverage alone requires thousands.  Then add in the cell phones.  Talk about a pileup......!
« Reply #2 on: February 01, 2017, 02:14:59 AM »
Nice link. You cannot use the VFO to transmit on 60 meters.
KK6RPX
« Reply #3 on: February 01, 2017, 06:39:14 AM »
Thanks! I knew it had to be something like that. I bet now that I know what it is I'll find it in the manual.
Much appreciated!
WB2EOD
« Reply #4 on: February 01, 2017, 10:18:42 AM »
I have a '991.
Used it on 60 meters once or twice but without a proper antenna, the tuner had a hard time with it.
The 60 meter "channels" can only be used in "memory" mode.
Those memory channels can not be changed or deleted.
This is covered in the manual but I can't recall which page
WB2EOD
KG5NFE
« Reply #5 on: October 28, 2017, 10:42:44 AM »
Turn your FT991 on...
Look on right side and press the V/M button.
Press the F(M-LIST) button.
On the menu find the MCH button and the memory screen will display.
Use your Multi dial in center of radio to turn to the preprogramed 60meter channel you want.
When your finish to back out of the memory channels press the V/M button again and you back to normal operations.
KK6RPX
« Reply #6 on: October 28, 2017, 12:12:42 PM »
Yup, that was the problem. Have to be in memory mode which is kinda dumb. Also, there is no good way that I could find to tune up so I used an audio generator to make a tone. Worked fine but silly there is no easy way to tune.
KC9UOD
« Reply #7 on: October 28, 2017, 12:47:02 PM »
My FT8900 had a problem transmitting on 50mhz band and turned out you need to transmit on the secondary display witch was in manual. turns out out Reading the manual is a good thing! Smiley
