Author Topic: Direct TV Dish  (Read 3313 times)
KT4NR
« on: February 03, 2017, 10:35:00 AM »
So someone in my development chucked out an Oval Direct TV Dish with the feed, a vertical section, and who knows what else attached. I am not a microwave guy (yet) but I know enough to dumpster dive for such items.
Is this dish of use for future microwave ops? which bands?
Thanks!
« Reply #1 on: February 03, 2017, 11:07:29 AM »
I would leave it in dumpster. Its for around 12ghz and they are easy to get used as they do not reuse them when service is discontinued and of little value.
« Reply #2 on: February 03, 2017, 11:12:13 AM »
They are useful for 6 and 10 GHz.  I've personally worked as far as 300 miles with one, operating from Hammonasset beach in Connecticut.  The other guy was on Reddish Knob in WV.
Zack W1VT
W4KYR
« Reply #3 on: February 03, 2017, 11:18:04 AM »
Thanks!
I think you can use that for FTA (Free To Air) non encrypted channels satellite TV using a different feed horn and buying an FTA receiver.
http://www.satelliteguys.us/xen/forums/free-to-air-fta-discussion.24/
You should be able to use that dish as a reflector for Broadband - Hamnet, HSMM-Mesh and maybe AREDN . That is where hams take certain specific kinds of wifi routers and re-flash them to use on the microwave ham bands.
http://www.broadband-hamnet.org/
http://www.aredn.org/
N1UKX
« Reply #4 on: February 03, 2017, 11:21:19 AM »
Could make a slot antenna for 2 meters with it........
KT4NR
« Reply #5 on: February 03, 2017, 12:41:10 PM »
Great ideas all. Thanks!
Will hold onto it for now until I or someone around me can use it.
W4CDO
« Reply #6 on: February 03, 2017, 12:49:10 PM »
You could use it to build a radio telescope. See the my reply to post "Ideas for Using an Old Satellite Dish" under "Homebrew".
Jerry W4CDO
N8EKT
« Reply #7 on: February 03, 2017, 05:41:33 PM »
a parabola focuses much more than just rf
you can use it for long range listening or you can cover it in foil furnace tape and make a solar furnace
K3GM
« Reply #8 on: February 04, 2017, 06:10:36 AM »
There's an article in a recent issue of QST on how to modify an oval dish into a 2m slot antenna. W6NBC is the author, and I believe his work is available online.
ONAIR
« Reply #9 on: February 04, 2017, 03:17:22 PM »
Keep it!  Many hams in HOAs use them to disguise ham antennas by using the connecting "cable"!   Roll Eyes
KG7CSS
« Reply #10 on: February 10, 2017, 11:51:29 AM »
Thanks I seen lot of dish tv antennas super cheep or  in the free pile at yard sales.
VE6MB
« Reply #11 on: February 10, 2017, 12:12:48 PM »
The dish is not useless. I can't speak specifically for effectiveness of the oval shaped ones. But the standard round 18" offset dish is usable starting at around 2.4Ghz (too small for 1.2Ghz) and higher. Back in the day of the AO-40 satellite with S-mode (2.4Ghz) downlink I used a 24" unit and downconverter (no preamp) to monitor the satellite.
Good Luck with it.
Tino, VE6MB
N0YXB
« Reply #12 on: February 10, 2017, 08:03:05 PM »
Thanks!
The is cool, thanks for that.
FORMER_K2OOL
« Reply #13 on: February 13, 2017, 11:39:03 AM »
Free to air,you need a bigger dish 36 inch dish
http://www.sadoun.com/Sat/Order/Dishes/Free-to-air-satellite-dish.htm
