Author Topic: Digital display for Yaesu FT-401b using the Arduino Uno  (Read 9469 times)
N5KBP
« on: February 19, 2017, 08:55:14 PM »
This is the latest working sketch for the Arduino UNO. Any comments or suggestions invited.
Marty
N5KBP
/*  Program to emulate a Yaesu YC-601 digital display for the old Yaesu FT401B
 *  Transceiver. It takes the output of the VFO. Counts it then manipulates the
 *  numbers to show the output on a TM1638 8 segment led display/key board from ebay.
 *  It uses the buttons built into the TM1638 for user input ie Band, mode and calibration
 *  setup. It takes a little outside hardware. You have to condition the input
 *  to a square wave. I use a 74hc4046 to do that then the frequency must be divided
 *  by 2 to get the 9 mhz output that the Yaesu outputs down to a frequency the Arduino
 *  Uno can handle. That is done with a 74hct4040 shift register. All the info on this can
 *  be found with a little help from Google. I plan on adding a power down reset circuit
 *  and code later to write the config data to the EEProm on power down.
 *  My experience is in Visual Basic. This is my first attempt at C so
 *  It is not as structured as I would like and is probably a memory hog. But it works.
 *  Thanks to all the library writers, code sharers and circuit sharers.
 *  I have thourally enjoyed this project and like most programs it will
 *  suffer from feature bloat eventually. :^)
 *  Code is released under the GNU GPL license
 *  Marty Duplissey
 *  N5KBP
#include <FreqCount.h>
#include <TM1638.h>
#include <EEPROM.h>
struct config
  byte initflag;
  boolean  displaytens;
  byte lastmode ;
  byte lastband ;
  unsigned long bandoffset[11];
  config configdata;
  int mode ; // 0 = LSB, 1 = USB, 2 = CW/Tune 3 = AM
  int currentband ;
  unsigned long oldcount;
  unsigned long count;
  int modeoffset[] = {150,-150,-70,0};  // LSB,USB,CW,AM
  byte buttons;
  unsigned long buttonpressed;
  char modestring[4] = {'L','U','C','A'};
  String displaystring; // string to send to display
  int calamount = 1; // amount to change with calibrate buttons
// define a module on data pin 8, clock pin 9, strobe pin 7
 TM1638 module(8,9,7);
void setup() {
 EEPROM.get(0,configdata);
 if (configdata.initflag != B10111010)
   configdata.initflag = B10111010;
   configdata.displaytens = true;
   configdata.lastmode = 0;
   configdata.lastband = 0;
   configdata.bandoffset[0] = 1270000; // 80M
   configdata.bandoffset[1] = 1620000; // 40M
   configdata.bandoffset[2] = 2320000; // 20M
   configdata.bandoffset[3] = 3020000; // 15M
   configdata.bandoffset[4] = 3720000; // 10A
   configdata.bandoffset[5] = 3770000; // 10B
   configdata.bandoffset[6] = 3820000; // 10C
   configdata.bandoffset[7] = 3870000; // 10D
   configdata.bandoffset[8] = 1920000; // WWV 10 MHZ
   configdata.bandoffset[9] = 3620000; // 11M
   configdata.bandoffset[10] = 0;// change to 1070000  for 160m on FT101
   EEPROM.put (0,configdata);
  mode = configdata.lastmode;
  if (configdata.displaytens == false) calamount = 10;
  // if not showing 10's digit change calibrate by 100 hz per button press
  currentband = configdata.lastband;
  //Serial.begin(57600);// for debugging
  FreqCount.begin(100); // Gate time 1/10 th of a second
  module.clearDisplay();
void loop() {
  if (FreqCount.available()) {
    count = FreqCount.read();
    // count = 447500; //debug code comment out for real use
    count = count * 2; // compensate for the / 2 before
                       // counting done in hardware because of the
                       // limitations of the ardiuno
    if (count == oldcount + 1){// anti jitter code
      count = oldcount ;}
    if (count == oldcount - 1){
      count = oldcount;}      // end anti jitter code
    oldcount = count;
    // count = configdata.bandoffset[currentband]- count; //Use instead of following
    // line if using with FT101
    if (currentband != 10) count = configdata.bandoffset[currentband]- count;
    count = count + modeoffset[mode];
  if (configdata.displaytens == false)// drop 10's digit
    unsigned long newcount = count / 10;
    int roundtest = count % 10;// round display after integer division
    if (roundtest > 4) newcount = newcount + 1;
    displaystring = String(newcount);
    if (displaystring.length() < 6) displaystring = " " + displaystring;
    displaystring = (" " + displaystring);
    displaystring = modestring[mode]+ displaystring;// add mode letter to left most digit of display
    module.setDisplayToString(displaystring,0b0000010010);
   else
    displaystring = String(count);// show 10's digits
    if (displaystring.length() < 7) {displaystring = " " + displaystring;}
    module.setDisplayToString(displaystring,0b0000100100);
  buttons = module.getButtons();
  if (buttons != 0){
    switch (buttons) {
     case 1:// mode button
       if (buttonpressed >= millis())break;
       if (mode < 3)
        mode = mode + 1;
       else
        mode = 0;
        configdata.lastmode = mode;
        buttonpressed = millis()+400;
      case 2:// switch between 10s digit showing
         if (configdata.displaytens == true)
            configdata.displaytens = false;
            calamount = 10;// Move 100 hrz with cal button
         else
            calamount = 1; // Move 10 hrz with cal button
      case 4: // Band up button
         if (currentband < 10)
          currentband = currentband + 1;
         else
          currentband = 0;
       configdata.lastband = currentband;
      case 8: //Band down button
        if (currentband > 0)
         currentband = currentband - 1;
        else
         currentband = 10;
       case 32:// Calibrate up button
        configdata.bandoffset[currentband] = configdata.bandoffset[currentband] + calamount;
        buttonpressed = millis()+200;
       case 64:// Calibrate down button
        configdata.bandoffset[currentband] = configdata.bandoffset[currentband] - calamount;
       case 128:// write config to EEPROM
KB8BAB
« Reply #1 on: March 18, 2017, 07:05:17 AM »
Fun isn't it?
I did something similar for my Kenwood but went a few steps further. Now have the system tied to my PC for "point and click" operation with a panadapter.
Love the Arduino platform...
Bart
KB8BAB
N8CBX
« Reply #2 on: April 01, 2017, 07:50:20 AM »
Fun isn't it?
Yes.
I designed a triode tube amplifier control board and integrated an Arduino Micro to monitor plate/grid currents & HV level, warm-up timer, slaved to PTT line, sequential relay control, and indicator lights for the front panel. Then designed a second Ardunio to present SWR-PWR, current levels and other amplifier parameters to a 40x4 LCD display on the front panel.
Jan N8CBX
Dayton Ohio - The Birthplace of Aviation
N5KBP
« Reply #3 on: April 01, 2017, 08:01:15 AM »
I am thoroughly enjoying playing with this Arduino. During this project I have learned that the regular Arduino uno uses a ceramic resonator instead of a crystal. This created a drift issue with the counter. I have found a new version from Asia that uses a different USB controller and appears to use a crystal as a reference. I have ordered a few and am going to give them a try. I also found a really cool touchscreen/TFT display combo that only uses 2 pins to talk to the Arduino and has a really cool WYSIWYG programming system. It's called Nextion. I have ordered a 4.3 inch display and have downloaded the programming software to build the screen. When it gets here I'm going to change out the led display and give the Nextion a shot. Should be pretty cool.
Marty
N5KBP
