Author Topic: Weighted VFO Knob in general  (Read 4474 times)
KD7RDZI2
« on: May 06, 2017, 06:26:50 AM »
The Drake R8 that has a very light VFO Knob. I like it is light. Is there a mechanical reason why they chose a light one or just a mere reason of cost? Is there any cons for a heavier knob in rigs?
« Reply #1 on: May 06, 2017, 07:52:43 AM »
You have to remember that VFO shaft and bearings/bushings have to support this weight. If you weight it with a mixture of lead shot and epoxy in hollow recess on back of knob to improve feel make sure to lube shaft and its bearings/bushings regularly.
WA3SKN
« Reply #2 on: May 06, 2017, 02:37:35 PM »
If you like it, enjoy it!
73s.
-Mike.
LUCYAJONES
« Reply #3 on: October 10, 2017, 09:41:10 PM »
:)On the off chance that you like it, appreciate it!
lucya
WB4SPT
« Reply #4 on: October 11, 2017, 10:29:49 AM »
Weight/inertia tends to smooth the action, but the starting and stopping require more effort.
N4MQ
« Reply #5 on: October 11, 2017, 03:19:39 PM »
Would felt on the back of the knob not also provide the LOADING of the knob to simulate a heavier feel??  Old british cars had a friction mechanizim on the steering shaft to DAMP the steering FEEL. Woody
KOP
« Reply #6 on: October 12, 2017, 12:02:57 AM »
...also used those awful friction dampeners on the Triumph Spitfire.
     Friction is not at all the same as inertia. When you have a notoriously light (read frictionless) and precise VFO like the TS-830S there is an advantage to a weighted knob. I find there is less of an advantage when using one of the old Jackson reduction drives or the Swan/Siltronix duplex drives.
It seems this is exactly the opposite of many opinions. So we have a goodly portion that prefer weighted with the frictionless (usually optical) drives and those that prefer the weighted mechanical drive. A fair portion accept it as is and do nothing. Very few add friction on other than mobiles .  I put a little friction on my FT-857.
     It really is a matter of personal preference. The weighted knob for my TS-830S sits in a drawer. The knob I built for my Tempo 2020 is on the radio. The HW-101 and the Siltronix are as is . So I can't make up my mind either.
     Is that "general" enough for you ?
66 days, 9 hours, 55 minutes and 59 seconds
« Reply #7 on: October 13, 2017, 11:37:03 AM »
I encountered this same problem on a homebrew transceiver.  I spend countless hours "loading" the rear of the tuning knob with weight as well as using the felt option. I found that smooth leather washers worked better here.
The felt option gave me an unnatural drag which I didn't like. The leather washers was better. The weighted knob gave me a problem with the weight being in one spot.  When the knob was weighted at one spot and the knob was at the 1-3 o'clock positions (as well as 180 degrees from that) the knob would drift to the 6 o'clock position.
My final solution was to load the knob with equal amounts of weights at 3 or 4 positions on the back of the knob to give me the right feel with no drift as well as the option of "spinning the knob" when I wanted to.
Lead shot and a glue gun works fine for this mod. (I like glue from a glue gun because it can be peeled of if a change is necessary)
