Author Topic: icom ic-2730a crossband repeater setup  (Read 2640 times)
DV2AWN
« on: July 12, 2017, 06:14:59 AM »
hello everyone,
     i just bought an icom ic=2730a dual band mobile radio and i am trying to setup the crossband repeater function. i can't seem to add the crossband repeater function using the instruction found on the icom page, specifically that of with the radio turned off, press and hold both the main button+moni then pressing the power button. is there something wrong that i am doing? can someone please help me with this?
     thanks and 73
de DV2AWN/Amboy
K5BBC
« Reply #1 on: July 12, 2017, 08:16:56 AM »
Be sure you have all three buttons actually depressed, and hold them in until it's powered up.
My IC-2820 and Kenwood TM-V7 had similar procedures. But if you moved your finger or let off of the button at all, it required another try.
LA9XNA
« Reply #2 on: July 23, 2017, 12:01:21 AM »
The X-band might require a diode modification to be enabled.
When the ic-2820 came out I did a lot of these modifications.
Check with your local Icom dealer if this function is enabled.
NH7YS
« Reply #3 on: July 23, 2017, 02:17:56 PM »
Try This:
To Activate Cross-Band Mode
Before you activate cross-band, set the frequencies you will need. Frequencies can be set in VFO or using Memory Channels, or also using VFO and a Memory Channel.
Note: Once this procedure has been completed, the cross-band feature will now appear in the menu unless a full reset is performed.
1. Press and hold both MAIN keys, MONI, and then press power.
2. Press MENU.
3. Rotate a tuning knob and select EXMENU.
4. Press MW. Rotate a tuning knob and select OTHERS.
5. Press MW. Rotate a tuning knob and select RPT M.
6. Press MW. Rotate a tuning knob and select START.
7. Press MW. Rotate a tuning knob and select YES.
8. Press MW. The display will show both bands with rPt listed under the frequencies. The cross-band feature is now activated and you may operate in cross-band mode.
To Exit Cross-Band Repeat Mode
1. Press Menu.
2. Rotate a tuning knob and select YES.
3. Press MW. To return to cross-band repeat mode, perform steps 2- 8 as above.
Tad, NH7YS
