Author Topic: kenwood tm-710ga won't beacon in the shack!  (Read 3930 times)
K8CPA
« on: July 13, 2017, 06:02:54 PM »
There's a catchy title that should grab some eyeballs.
Here's what's going on guys. I picked up a Kenwood TM - 710 Ga and I want to use APRS. Well, The Radio will beacon Just fine on APRS in the truck. GPS locks on works really good.
Here in the basement in my amateur Radio Shack is another story!  Angry
I think I've done everything except stand on my head and that thing won't lock on down here for nothing!
I understand why and I understand there is a solution to shutting off the GPS and manually entering in your information; which if the YouTube video I watched is correct...I did that.
But it will not beacon.... the GPS icon is solid and it will not Beacon at all. I can send messages but it won't Beacon!
I would pull my hair out... but I don't have much to begin with...  Shocked  so I need some help.  Undecided Sad
Anyone happen to know a solution to tell this GPS to set straight and fly right so that I can Beacon without having to rely on it to be flashing?
Many thanks & 73!
Chuck K8CPA
K8CPA
« Reply #1 on: July 15, 2017, 08:01:56 AM »
cancel this....figured it out
VE6MB
« Reply #2 on: July 18, 2017, 03:03:10 PM »
It would be good to know what your solution was...might help someone else out with the same problem.
My guess is you either:
Forgot to engage the BCON function, or
Your squelch was open causing the radio to hold the beacon TX.
73, Tino VE6MB
Calgary, AB
K8CPA
« Reply #3 on: July 30, 2017, 11:43:15 AM »
I am currently posting from my phone so I can't exactly cut and paste links. But if you go to YouTube put in my call sign in my YouTube channel should pop up and look at the video work tells how to disable the GPS in this radio and that is how you do it.
