Author Topic: eham.net website - not responding through Comcast/xFinity  (Read 2966 times)
AC2TQ
« on: August 02, 2017, 06:55:47 AM »
All,
  I cannot seem to access eham.net through Xfinity in NJ.  The website responds to a ping, which means that I can resolve the IP (from DNS) and the Ping (ICMP) response is enabled.  I get a site timeout when going to it from any (IE, Edge, Chrome, Firefox) web browser.  (Note: I did NOT try to telnet to port 80 of the server, but that should result in the same timeout.  I will try later.)
It seems eham.net has some type of protection that has blacklisted some (all?) xfinity addresses from NJ.  Can someone from eHAM check the security/connection logs for evidence of this?  Can we rectify?
(Note: I am posting this from work that has an independent connection.  Further, Verizon wireless connectivity is fine as well.)
ping eham.net
Pinging eham.net [69.36.242.135] with 32 bytes of data:
Reply from 69.36.242.135: bytes=32 time=94ms TTL=50
Reply from 69.36.242.135: bytes=32 time=95ms TTL=50
Reply from 69.36.242.135: bytes=32 time=91ms TTL=50
Ping statistics for 69.36.242.135:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 91ms, Maximum = 95ms, Average = 93ms
ping www.eham.net
Pinging www.eham.net [69.36.242.135] with 32 bytes of data:
Reply from 69.36.242.135: bytes=32 time=93ms TTL=50
Reply from 69.36.242.135: bytes=32 time=96ms TTL=50
    Minimum = 93ms, Maximum = 96ms, Average = 94ms
-73
Angelo
AC2TQ
N2MG
Administrator
« Reply #1 on: August 03, 2017, 12:49:27 AM »
Your IP address was blocked by our sometimes over-anxious security code.
Please try again.
Mike N2MG
KC4ZGP
« Reply #2 on: August 03, 2017, 09:30:31 AM »
Well Angelo, what you describe in detail tells me there is a problem somewhere along the line.
The problem needs to be eliminated.
Glad I could help.
On 1.8136MHz Morse, 2200UTC.
Kraus
