Author Topic: How to do a MARS modification . . . on a Software Defined Radio?!?!???  (Read 16187 times)
KD8M
« on: August 05, 2017, 01:00:17 PM »
I have been following the Software Defined Radios for quite some time.   It occurred to me . . .
How does one do a modification to an SDR so one can transmit on the authorized out-of-ham-band frequencies?
In my radios, I disconnected a diode or two.  Anyone know what to do with SDRs?
K0BT
« Reply #1 on: August 05, 2017, 02:56:31 PM »
It's usually done through firmware, which is code that is embedded into the microcontroller or FPGA inside the radio. The vendor defines which features are activated by changing the firmware, which is then sometimes tied to a device hardware ID to make it only work on that one radio.
N9AOP
« Reply #2 on: August 25, 2017, 09:53:31 AM »
Elecraft does it this way.
Art
WB8LBZ
« Reply #3 on: August 31, 2017, 06:55:52 AM »
When I owned a Flex 3000 you needed to contact Flex for the change. I'm not what is involved since I didn't need it. I think Icom is still using the diodes.
73, Larry  WB8LBZ
El Paso, TX
WC4R
« Reply #4 on: September 21, 2017, 07:33:47 AM »
I sent Flex a copy of my MARS license years ago for a mod to my 5000A. They sent me a file to open the TX writing to the firmware.
