Author Topic: Is there any way to use a Heil icM mic with FTDX-5000?  (Read 12322 times)
KW4CQ
« on: August 16, 2017, 04:47:01 AM »
I have a new Heil icM condenser mic that I would like to try using with my Yaesu FTDX-5000 transceiver.  I've used other dynamic and condenser mics with this radio but the icM requires something else to make it work I believe.  Any thoughts or suggestions would be greatly appreciated.
73, Bob KW4CQ
NA4IT
« Reply #1 on: August 18, 2017, 03:12:20 PM »
That mic was specifically designed for Icom rigs that provide phantom power to the mic.
K0BT
« Reply #2 on: August 20, 2017, 03:46:04 PM »
You can probably make it work with a two-component bias adapter, as shown on the bottom of this page:  https://heilsound.com/heil-amateur-radio/support/dsp-settings/all-things-yaesu/
The mic will probably be "hotter", so expect to reduce the mic gain on the radio by quite a bit.  Please let us know how it works.
K0BT
« Reply #3 on: August 31, 2017, 06:19:57 PM »
How did it work?
