Author Topic: LNR LD-11 vs Aerial-51 Sky-SDR QRP radios  (Read 6061 times)
VR2YAL
« on: September 11, 2017, 06:00:51 AM »
I was looking at the LNR Precision LD-11 when I also came across its twin from Germany, the Sky-SDR from Aerial-51.
https://www.aerial-51.com/new-sky-sdr/
On paper they look be the same but with very minor differences in specs. Looks-wise they are more or less the same unit!
Anyone used or purchased the German version that they can give feedback on?
KB2SDR
« Reply #1 on: September 25, 2017, 08:04:19 PM »
They are the same radio.
AE0Q
« Reply #2 on: September 26, 2017, 08:07:47 AM »
Notes from AERIAL-51:
Doby LZ2TU designed and built the LNR LD-5, LD-11, and SKY-SDR.
The LD-5 was 1st generation and significantly worse than the LD-11 (2nd generation).
The SKY is now 3rd generation which is where they changed from single-threaded to multi-threaded firmware, plus a few other changes  (different knob, back to square buttons, louder side-tone, more volume out of the speaker, etc.).
In the meantime the LD-11 has received all of the changes of the SKY except the color of box and shape of buttons.
The biggest difference is, the LD-11 has just an average user manual.  The SKY-SDR has a more thorough manual that explains how to use the radio.
The SKY-SDR has receiver performance on par with the Ten Tec Eagle. The filters seem just as good and in almost all cases, there is about 1 S-unit lower noise level on the SKY than on the Eagle.
Glenn AE0Q
Glenn and V-NATCH Katie,
HP-O, MXB, MJB, XF
http://www.hoopsandjumps.com/
http://funagility.webs.com/
WB4M
« Reply #3 on: September 30, 2017, 11:06:49 AM »
Thanks for that info Glenn. I had been considering an LD-5, but think now I'd spend a bit more for the LD-11.
