Pages: [1] 2 3 Next   Go Down
Author Topic: Can't decode FT8, but can decode JT65 signal  (Read 15658 times)
HS0ZIB
« on: September 16, 2017, 06:06:25 PM »
This is my first attempt to decode an FT8 signal.
I'm running version 1.8.0-rc2 of WSJT-X.  I am receiving a clear FT8 signal on 17 mb.  (I know that it is an FT8 signal because of the 15-second transmit time).
I'm not overrunning the microphone input - I have set input levels at 0dB and in WSJT-X, the input level is always in the green level, at about 35dB.
The signal will not decode!  When the blue decode button flashes just before the end of the 15 seconds, no text is displayed in the text window.
My laptop clock is synchronised using an atomic clock synchronisation application.
If I then tune a few KHz up to a weak JT65 signal, and switch the WSJT-X mode to JT65, the signal is decoded fine!!
What's up?  Why can't I decode the FT-8 signal (or any FT-8 signal, weak or strong, that I've tried)
Any suggestions?  I've tried to reduce the input levels even more, but there is no decode at any level that I've tried.
« Reply #1 on: September 16, 2017, 06:26:06 PM »
Increase the input level,  Mine runs about 50 to 60 at all times when actually decoding signals.  Resting at about 35 with absolutely no signal.  I suspect you don't enough signal going to the pc.
HS0ZIB
« Reply #2 on: September 16, 2017, 06:45:31 PM »
I've tried with an increased signal level.  Tested different increases until well into the red.
No decode, nada...
JT65 decode is fine ...
HS0ZIB
« Reply #3 on: September 16, 2017, 07:36:08 PM »
Wait!  Maybe I have the answer.
From this thread:
http://www.eham.net/ehamforum/smf/index.php/topic,116476.0.html
I read that there is a strange 15-second digital signal on 18102 KHz that is not FT8.  Well, that's the same frequency that I'm receiving this strong 15-second signal.  So maybe I am receiving something that is not FT8......
But the other thread reports that this signal comes from a station in Cuba.  That's the other side of the world from me, seems too strong for that QTH.  So maybe there is someone more local to me (eg Asiatic Russia etc) who has the same problem as the Cuban station.
I will tune around and look for some other 15-second signals and try to decode them as FT8....
HS0ZIB
« Reply #4 on: September 17, 2017, 03:15:36 AM »
Unfortunately, that was not the answer...
I found some more 15-second signals, loud at my QTH.
I can't decode them!  And the JT65 signals can be decoded just fine.
Very frustrating - I can't think what the problem is.  It doesn't endear FT8 to me as an easy mode to decode.
WB2KSP
« Reply #5 on: September 17, 2017, 04:04:45 AM »
What are you settings?
AJ8MH
« Reply #6 on: September 17, 2017, 06:41:14 AM »
You have to be in USB.  I don't think I saw it printed anywhere, but I just tried LSB and couldn't get anything to decode.
HS0ZIB
« Reply #7 on: September 17, 2017, 06:50:00 AM »
Yes, I'm in USB.
As mentioned, I can't decode FT8, but if I tune 2 KHz up to a JT65 signal and switch to JT65 mode on the software, it decodes fine!
I'm stumped!
ND6M
« Reply #8 on: September 17, 2017, 07:09:17 AM »
Well, for starters.try deleting the entire WSJT program and then reinstall it.
Good luck
« Reply #9 on: September 17, 2017, 08:06:26 AM »
Me too..  Yes, try a fresh re install.  Did the older RC1 version decode FT8 for you?  I can't think what this could be, if you can decode JT65 and JT9, then you must have the correct soundcard installed and good connections...  I would have to see this.   Perplexed here in Missouri...
AJ8MH
« Reply #10 on: September 17, 2017, 01:15:35 PM »
Is FT-8 timing more critical?  Maybe your clock application isn't working correctly.  Most of the stations I work are within .1 - .4 seconds of my clock.  I'm using Meinberg NTP on 2 computers and it seems to work great.  Had problems with Dimension 4 on one computer, so I changed it out on both.  My sound card is set to DVD quality, but never had a problem with CD quality.
Never used JT65.
WB2KSP
« Reply #11 on: September 17, 2017, 01:51:37 PM »
Good point. I'm using dimension 4 which is freeware. I have it sync every ten minutes to a local NY server and my clock is always in perfect sync with WWV.
« Reply #12 on: September 17, 2017, 02:04:00 PM »
I don't think the timing is any more critical. Unfortunately are the only one on the planet having this problem.
How do you feel about posting screen shots (you can use postimage) of all of your settings on WSJT-x.   Let us look them over, and maybe we can come up with something.
HS0ZIB
« Reply #13 on: September 17, 2017, 06:20:39 PM »
I never used RC1 with FT8.  I decided to download the latest version (RC2) because of all the interest in FT8, and to see what I was 'missing'.  Well, I'm still missing it!
My clock sync program syncs with an external time-server every 5 minutes, so that's not the problem.
I think I'll uninstall the RC2 version, then download RC1 to see if that works.
« Reply #14 on: September 17, 2017, 07:26:27 PM »
Post some pictures.  Post pictures of the waterfall on 20 meters.  We need to see what is wrong..
What is your radio? what is your interface?  What is your computer.?  What about JT9, can you decode that.  WSPR?  Have you tried to decode WSPR signals?
« Last Edit: September 17, 2017, 07:28:43 PM by K0UA » Logged
Pages: [1] 2 3 Next   Go Up
