Author Topic: ICOM's on the 630 meter band  (Read 1294 times)
AA2UK
« on: September 21, 2017, 10:17:58 AM »
While I wait to either hear back from the UTC or if no response after 30 days start transmitting. Last night I tuned my IC-7410 to the 630 meter WISPR freq and was able to Rx stations in Canada, the US and ZF1EJ (EK99). I'm encouraged since my Rx antenna was my 6 meter Moxon (for real). I do understand building a "short" Tx vertical and base ATU will have it's challenges.
I have read a few articles on converting the ICOM IC-735 for use on the 630 meter band.
I hope to source one soon to do the conversion, this allows the transceiver to well Tx & Rx on 630 meters.
http://alain.st.free.fr/site1/aspicsite/IC-735/500KHZ/735-630m-mod.pdf
I have an IC-7410 that does a good job receiving but it doesn't look like it can directly transmit on 630 unless I go the transverter route. Has anyone seen a 7410 mod(s) that will allow it to Tx?
AA2UK, Bill
G8YMW
« Reply #1 on: September 21, 2017, 03:46:18 PM »
Hi Bill
Are you receiving on the Moxon or the Moxon's coax outer against ground?
As for a transmit ATU, have you considered a variometer as the RF voltages may flash over any caps
73 de Tony
Windows 10:  Making me profane since March 2017
AA2UK
« Reply #2 on: September 22, 2017, 02:50:05 AM »
Hi Bill
The shield of the coax and the center conductor are not shorted in other words the shield is ground. My guess is the Moxon is acting like a small loop.
I have procured a working IC735 from K1JT for the project. I'll modify it to work on 630 meters.
I'll be using a short vertical with a base loaded coil and variometer.
AA2UK
Bill
