Author Topic: Fan Question  (Read 5810 times)
« Reply #15 on: October 03, 2017, 04:21:41 AM »
It is always more efficient to suck hot air out of case than to blow it around in case as it can heat up other areas in process. Muffin fans tend to loose efficiency quicker with back press vs same an\mount of suction pressure differential.
This is not technically accurate. By itself, the fan will perform equally in both cases. What often makes the difference in applications is not understanding the ducting effect on the entrance to the fan.
It is also worth noting that the rated fan CFM is the free air volume. Once installed in an actual application, a lower CFM will be realized.
