Author Topic: Testing the TNC in a Kenwood TS2000  (Read 1431 times)
« on: October 04, 2017, 10:33:05 AM »
Is there an easy way to test whether the TNC in the TS2000 is working or not?  We don't have a DX cluster in town, so I can't use the DX spots function.  Will the TS2000 decode APRS data, and if so, how do I have to set that up?
Also, I have a Kenwood TH-D7A HT that does packet.  Is there a way to set it up to send a message to the TS2000 that the TS2000 could decode if the TNC was working?  I am trying to get the TS2000 going on Sky Command, and I have all the settings correct, as far as I can see, but I can't get it working, and I am wondering if the TNC in the TS2000 isn't working correctly.  The TH-D7A is decoding other's APRS messages, so it is decoding ok, and when I try to start Sky Command, the TH-D7A does sent out a packet burst, and the TS2000 shows that it is receiving the signal on the subreceiver, but it never seems to send any data back to the TH-D7A.
Any help on how to test the TNC in the TS2000 would be most appreciated.
K0BT
« Reply #1 on: October 04, 2017, 11:56:59 AM »
This might be helpful.  http://wa8lmf.net/bruninga/aprs/skycommand-kwd.txt
« Reply #2 on: October 04, 2017, 09:52:18 PM »
thanks for the link. I have seen that before. I followed it completely and still can't get Sky Command to work.
