Author Topic: RFI on Enphase  (Read 2988 times)
VK4UR
« on: October 04, 2017, 03:42:30 PM »
I am preparing to install a 6.2kW solar system and because of late afternoon shading have been advised to use Enphase S270 micro inverters.  I have read conflicting comments from hams with and without any RFI problems.  The S270 is sold in Australia where I am now living.  I am not sure how it equates with what is sold in the USA.  Can anyone provide any advice/experience about RFI from Enphase micro inverters.
Jim
WX8B
VK4UR
WB4SPT
« Reply #1 on: October 08, 2017, 09:02:08 AM »
AUS C tick mark follows CE mark fairly closely.   Ask if the product has either/both.  I've had good luck actually getting Rad emission test reports from different vendors.  This can tell you what freqs you can expect noise.
KD8SKM
« Reply #2 on: December 01, 2017, 11:13:20 AM »
Jim:
A few questions here -
Are you doing this yourself or having it installed by a contractor?
Grid tied or off grid?
How bad and how late in the afternoon is your shading problem?
Most panels have bypass diodes that will shunt shaded cells - 60 cell and 72 cell panels usually have 3 or 4 respectively.
If you are doing an off grid system we can potentially help you.  System performance is best when each solar panel or Pair has its own controller during partial shading conditions.  however if late in the day like more than 3 hours past solar noon the power gain / loss would be minimal.
Check out our Apollo product at www.diysolarforu.com
We can do 12, 24 or even 48 volts with this by stacking 2 24 volt banks in series.
Cheers,
Rob
KD8SKM
