Author Topic: S. 1534 Amateur Radio Parity Act pulled from Subcommittee markup  (Read 26040 times)
K7JQ
« Reply #45 on: November 02, 2017, 07:14:48 AM »
I'd suggest using one of the rebuttals used by a hater--that this legislation only affects a very small percentage of those living under HOAs.  It is then obvious that the negative aspects, minimal and if any, will be far outweighed by the benefits offered by allowing licensed amateurs some consideration by Federal law.
Pete
Agreed. It's not as if every other house will sport a vertical or dipole. You might have maybe one or two hams (if that) in a large subdivision. There's much more chance of (unsightly) TV antennas, which are allowed by law, to spring up as people "cut the cord" and opt for free over-the-air TV. It could happen, as cable and satellite service prices continue to skyrocket...back to the days of rooftop aluminum.
Bob
N5BCN
« Reply #46 on: November 02, 2017, 12:24:02 PM »
Actually, the CAI did not support ARPA at all...but it got passed in the House and got submitted in the Senate. They focused on Sen Nelson (and a Senator in CA...name escapes me right now) to get on their side. Nelson wanted more concessions even after the League agreed to several changes (see  my initial post in this thread) which many hams could no longer support (including me).
Thanks for the clarification.  I'm a little surprised, actually, ARPA appears to be a pretty good deal for the CAI.
73 Brian N5BCN
K4FMH
« Reply #47 on: November 02, 2017, 12:57:05 PM »
BUT...they wanted an even "better" deal once the ARRL agreed to the prior antenna installation permission clause and the other language changes!
Frank
73 Brian N5BCN
KN6SD
« Reply #48 on: November 02, 2017, 05:39:55 PM »
To Anyone:
Any suggestions on how HR 555 / S 1534 can be made acceptable???
Nope, we would rather just complain about the ARRL...
I thought so.... So here's my latest ARRL complaint: They're studying another Entry Level Amateur Radio License scheme.  OMG: Here we go again, new license, NEW MANUALS to sell...
K1ZJH
« Reply #49 on: November 02, 2017, 06:22:49 PM »
that is silly and a waste of resources.
KN6SD
« Reply #50 on: November 04, 2017, 09:55:58 AM »
Not if you're caught in a "Loop"   Cheesy
Ya know, you just keep revisiting the same things over and over and over and over.....
Dang, almost got caught myself....  Roll Eyes
KN6SD
« Reply #51 on: November 28, 2017, 10:23:39 AM »
(K4FMH) Dr. Howell,
I sent you a private message via the E-Ham Message feature...
Russ
KN6SD
« Last Edit: November 28, 2017, 10:43:55 AM by KN6SD » Logged
KN6SD
« Reply #52 on: November 28, 2017, 11:12:30 AM »
So how does K4FMH respond to my message asking for his help at making ARPA better???
He blocks me!!! Wow, at this rate I don't see anything getting done by anyone, to many EGOS to stroke  Grin........
KN6SD
« Reply #53 on: November 28, 2017, 11:16:47 AM »
BTW: Here's what I have suggested to the League (and Frank) this last week...
Hi Tom,
Thank you for your response. I'm writing you again after reading an interesting article on the website Independent American Communities, here's the link to the article https://independentamericancommunities.com/2017/10/09/reality-check-hoa-managers-face-decline-of-their-industry-like-it-or-not/ .. It talks about the decline in HOA controlled communities, and that got me thinking. What if you scrapped the current Amateur Radio Parity Act language, replaced it with something similar to the attached "Homeowners Wireless Freedom Act" and added an exemption to HOA Governed communities as long as they allowed at a minimum X & Y antennas... I'm thinking along the lines of a Diamond X-510 (example only) mounted 12ft above the roof and a ground mounted vertical (or wire) antenna for HF in the rear of the property.
Now, if they (HOA) allow a licensed amateur at least two modest antennas, and the other radio services at least one Omni-directional roof mounted antenna similar to the Diamond, then they're EXEMPT from a total pre-emption. Now in a condo more than one antenna would probably be a stretch, but in a detached single family residence, I don't see a problem.. If the HOA wanted to allow more, that would be permissible under the new language, but not mandatory like the minimum antenna requirements. So I am basically purposing you come up with an OTARD equivalent for Transmitting Antennas.
It's not perfect by any stretch, but the new language would allow operators to get on the air with a decent signal. NO Tower or beam, but that was never going to happen anyway. And it gives the HOA clear and concise guidelines to abide by so there's little chance for litigation.
Of course, if the HOA is dissolved or the property was never governed by one, then the CC&R pre-emption kicks in all the way...
Just another idea to try to get some relief from Total Antenna Bans... Thanks for your time..
Russ Brill
KN6SD
Does my suggestion sound unreasonable???
Pages: Prev 1 2 3 [4]   Go Up
