Author Topic: Crystals from Ebay  (Read 4613 times)
KF7ZFC
« on: October 08, 2017, 07:40:27 AM »
I looking to buy crystals for a filter that I will use in a 17m or 40m SSB receiver.
Some EBay listings call out "8MHZ 8.000MHZ 8M Hz Quartz Crystal Oscillators HC-49S" and some just "8.000 MHz 8 MHz Crystal HC-49/S"
The first one says "crystal oscillator" and the second just "crystal"
Is the first one also just a crystal  since they are both 2 lead devices?
Am I confused or is there a difference between the 2?
Or are they using confused terminology because it can be used as an oscillator?
K1ZJH
« Reply #1 on: October 08, 2017, 08:17:03 AM »
A two lead device in a HC-49S case would most likely be s crystal and not an oscillator.  Most of those ads do add the word "passive" to the description, which is another clue that these just crystals.
KF7ZFC
« Reply #2 on: October 08, 2017, 12:23:36 PM »
Thanks
« Reply #3 on: October 08, 2017, 01:12:46 PM »
If you don't mind 10.000MHz, I rescued from the dumpster at work when the place closed down a bag of 500 off 10.0000 MHz HC-49/U crystals. You are welcome to a dozen....if you are going to Hamvention in Ohio next year or have a buddy who is and can collect, you don't even need to worry about postage!
Peter G3RZP
KF7ZFC
« Reply #4 on: October 08, 2017, 04:46:23 PM »
Thanks Peter but timing is off
« Reply #5 on: October 10, 2017, 01:51:42 PM »
If you want them sooner, I can put them in the mail. Green customs form, value 10c each......would only cost $2 or $3...
KF7ZFC
« Reply #6 on: October 12, 2017, 07:06:49 AM »
Peter
Thanks for your offer but I didn't see your post until today
I had already  bought 100 (10.000 mhz) for $4.86 with shipping from China
Steve
KF7ZFC
