Author Topic: Cable to hook up my Yaesu 101b to my Yaesu FL-2100B amp  (Read 2585 times)
N2BRD
« on: October 11, 2017, 09:46:14 AM »
I'm looking for help to hook up my 101b to my 2100b amp any help or Leeds to were I can find a set of plugs to do this ?
73 Steve N2BRD
KC4ZGP
« Reply #1 on: October 11, 2017, 10:17:24 AM »
Looking for help? You mean to make one?
I'm an excellent solderer. (Is that really a word?)
And Jim down the street. Why he can strip insulation from even the smallest of wire
and never break a strand. He might break wind often but that's just Jim.
Kraus
« Reply #2 on: October 11, 2017, 02:37:40 PM »
The handbook or operators manual will tell you what leads you need.
N5KBP
« Reply #3 on: October 13, 2017, 01:19:24 PM »
73 Steve N2BRD
If it has the ACC plug in the back all you will need is a 3 conductor cable. Wire it from the ACC plug pin 8 to terminal E, pin 7 to terminal ALC and pin 9 to terminal RY on the fL2100.  If yours has had the ACC plug removed and pins 1 and 2 replaced with a jumper you will have to get a new ACC plug. Remove the jumper on the rig and wire the ACC plug as described.  In addition you will have to jumper pins 1 and 2 on the ACC plug. The ACC plug is an Amphenol 86CP11. Use Google to find it or a reasonable facsimile. I've seen them on the auction site for around $10.
Marty
N5KBP
