Author Topic: Front panel labeling  (Read 5369 times)
WB8QGR
« on: October 18, 2017, 07:30:14 AM »
Has anyone tried the Decal Pro by Pulsar for labeling front panels?
Michelle
WB8QGR
G4AON
« Reply #1 on: October 20, 2017, 11:21:28 PM »
I just print the panel on gloss photo card and cover it with self adhesive clear book covering film.
Stick the card to the panel with 3M photo mount adhesive. Cheap and easy, it’s good enough for an everyday homebrew rig.
The software is an old copy of Corel Draw. Although I’m sure there are better packages.
A typical example is http://www.qsl.net/g4aon/g4aon_ssb_tx/
73 Dave
AK0B
« Reply #2 on: October 21, 2017, 07:47:35 PM »
Dave your panel was very high quality.  will have to try your method
KE0ZU
« Reply #3 on: October 22, 2017, 03:37:53 AM »
I use a more conventional approach making the labels with a "Brother" brand label maker, and over spray with flat clear.   Quick easy self stick labels.
The machine is inexpensive as are the cartridges, and there is a very wide selection of label cartridge color combinations and size.
Regards, Mike
https://mikeharrison.smugmug.com/
Pics and bold print are usually links.
KU3X
« Reply #4 on: October 22, 2017, 06:16:06 AM »
Nicely done.
I use the same thing.
Barry
W6EM
« Reply #5 on: October 22, 2017, 07:59:30 AM »
Yes, nicely done.  I have a Brother as well.  Black on clear tape cartridges are the way to go, so you see just the black letters over panel paint finish.   Black on white or white on black tape is fine for labelling parts drawers and such.  Reasonable prices for the cartridges on eBay...
Lee
DL8OV
« Reply #6 on: October 22, 2017, 09:50:57 AM »
The label printers work but be careful of what you spray on them afterwards as some aerosol sprays contain solvents that will dissolve them. I prefer the copy shop option as they have better printers but what I have always had problems with is labelling around rotary switches. It's bad enough that I have to get them 30 degrees apart by eye but I need to get the spacing right as well.
Any ideas how to do this right?
Peter DL8OV
G4AON
« Reply #7 on: October 24, 2017, 01:53:34 AM »
Peter DL8OV
Try FrontDesigner by Abacom.
http://www.electronic-software-shop.com/lng/en/electronic-software/
73 Dave
