Author Topic: What rigs have been modded for 630M?  (Read 4590 times)
« on: November 04, 2017, 06:31:08 AM »
Im particularly interested in Kenwood TS-940 and 950's.
A friend has an IC 7800 and the manual claims the European version already works there. Details please?
AE5X
« Reply #1 on: November 04, 2017, 07:41:17 AM »
Be aware that modifying a rig by clipping a diode to enable expanded tx capability doesn't do anything to the output filtering in place in the transceiver. As of late 2015, the only commercially manufactured rigs available in the US that do switch to appropriate bandpass filters on 630m are the Flex 6000 series.
Maybe more recent rigs like the IC-7300 or Apache Labs models  do as well...  Huh
AA2UK
« Reply #2 on: November 04, 2017, 09:24:16 AM »
I know Carl is aware of your concerns. However I have converted an ICOM IC-735 including retuning the filter after the TX mixer in addition to many other mods. Measured power using SA thru high power attenuators is _48dBm on frequency.
Bill AA2UK
AE5X
« Reply #3 on: November 04, 2017, 09:38:03 AM »
That's 63 watts if you mean positive 48 dBm. I'm curious what effect your tuning of the filters had on other bands?
AA2UK
« Reply #4 on: November 04, 2017, 09:55:58 AM »
I'm also running a 5 pole filter on the output of the rig I haven't tried measuring the power on the other bands since the conversion. The rig's for dedicated use on 630 meters only (TX). The power is only 30dBm or 1 watt on 2200 which I have no interest in operating and I can not accurately measure power at 2200. I'll be putting up a short Marconi T this week. I've got a BC-306-A WWII ATU/Variometer. Also an old RCA RF current meter to monitor antenna current.
I'm hoping to source a Hafler 9505 for use on 630. I'll end up having to pick RF off before the PA once I get the Hafler.
Bill, AA2UK
« Reply #5 on: November 04, 2017, 03:26:34 PM »
All I need is 10-100 mw and can take it from there.  Ive been told by a few that the TS-940/950 family is simple but KW refuses to release the info. Now that the bands are legal they may change their mind.
AE5X
« Reply #6 on: November 05, 2017, 04:41:56 AM »
There is a UK-centric YahooGroup dedicated to LF/MF operations. Since 630m and other bands have been available there for years, they might be better able to answer your question.
« Reply #7 on: November 05, 2017, 08:15:50 AM »
I would expect that to be public knowledge by now
W6RYO
« Reply #8 on: November 10, 2017, 03:40:12 PM »
I just made the mod on my IC-7300 and it definitely needs a low pass filter. The third harmonic is only down about 10 db. It is registering about 5 watts with an MFJ 970 (probably very inaccurate) into an MFJ 260 B dummy load. The built-in SWR meter reads very high here but I think it is reading wrong. The MFJ meter shows about 1.4 to 1.
