Author Topic: HamStick whip shortening question  (Read 2330 times)
KF7ZFC
« on: November 04, 2017, 12:19:18 PM »
I have used #8 solid copper wire to find the resonant points on 40m, 20m and 17m HamSticks. Using my antenna analyzer I cut a little bit at a time to arrive at resonance/low SWR.
Originally I had lowered the stainless steel whips but that caused the resonant frequencies to lower due to the whip now in the coil area. The copper wire I kept short just so it cleared the clamp collar it's in.
The whip diameter is slightly larger than the copper wire.
My question is when I cut the stainless whip shorter should I leave a longer length than what I cut the copper wire to?
K3LI
« Reply #1 on: November 04, 2017, 12:57:14 PM »
I would think they should be close to the same length.  There may be a small difference due to the corona ball on the end of the SS whip.  Personally, I would cut them a minimum of 1/4 to 3/8 longer than the copper and work them down.
« Reply #2 on: November 04, 2017, 03:45:20 PM »
I'd leave a little extra, just in case...
You should be able to slide the whip down at least an inch or so before it starts protruding into the coil.
and that much adjustment may come in handy (particularly for the 40m whip, which likely will have
sharper tuning than the others.)  You should be able to feel where the winding stops under the heat
shrink tubing on the outside of the antenna - that's the lower limit.  The actual tuning will depend on
your ground system and nearby objects, so it is helpful to leave room for adjustment as things change
in the future.
KF7ZFC
« Reply #3 on: November 04, 2017, 06:42:20 PM »
Thanks
