Author Topic: Please support the "Homeowners Wireless Freedom Act of 2018"  (Read 25952 times)
KN6SD
« on: November 04, 2017, 09:31:25 PM »
Please show your support by signing my Change.org petition at https://www.change.org/p/russell-w-brill-homeowners-wireless-freedom-act
Let's try to put an end to unreasonable restrictions that have an adverse effect on a persons ability to communicate...
Thank you,
Russ Brill
W9FIB
« Reply #1 on: November 05, 2017, 12:59:04 AM »
Thanks Russ!
Now all those that keep saying how important this (ARPA) is should be signing. Put your signature where your mouth is!
I did.
73, Stan
Walk a mile in my shoes BEFORE you tell me how bad they are.
KN6SD
« Reply #2 on: November 05, 2017, 09:59:28 AM »
Thanks Russ!
I did.
Thanks for your support....
Russ
N5BCN
« Reply #3 on: November 05, 2017, 10:29:48 AM »
Appreciate your effort, also signed.
73 Brian N5BCN
KN6SD
« Reply #4 on: November 05, 2017, 06:34:21 PM »
73 Brian N5BCN
Thanks for the support...
Russ
K1ZJH
« Reply #5 on: November 06, 2017, 11:40:09 AM »
I signed as well, but I think your efforts should also be directed towards the original bill's sponsors.  Otherwise this will be a feel good movement that doesn't go anywhere. You need an ally in congress to walk these through.
Pete
W9FIB
« Reply #6 on: November 06, 2017, 01:59:35 PM »
Why not each person that signs send it to their congressman/senators?
73, Stan
KN6SD
« Reply #7 on: November 09, 2017, 04:35:04 PM »
I appreciate everyone's support... IMHO: The Homeowners Wireless Freedom Act of 2018 is much better for all radio hobbyist........
Russ
KN6SD
« Reply #8 on: November 11, 2017, 08:35:37 AM »
I don't live in an HOA controlled neighborhood, but I do recognize the HOA situation is having a chilling effect on the installation of two-way radio systems in homes.
BTW: Almost ALL new homes are in an HOA. If you buy anything built in the last 20 years it has all kinds of CC&R's and most likely an HOA...
KN6SD
« Reply #9 on: November 17, 2017, 07:00:59 PM »
Thanks again to everyone that has signed the petition... Have a great Thanksgiving everyone...
 Best Regards,
 Russ Brill
NN4RH
« Reply #10 on: November 19, 2017, 04:48:07 AM »
Is this an actual piece of legislation in the Congress ?
Or just wishful thinking / feel good exercise ?
Has ANY "change.org" online petition EVER resulted in any real change ?
« Last Edit: November 19, 2017, 04:59:02 AM by NN4RH » Logged
W9FIB
« Reply #11 on: November 19, 2017, 09:22:35 AM »
Well if you don't try something, guess what would happen.........
Nothing.
Just like voting, if you don't vote, then you have no expectations to the results.
73, Stan
N2SR
« Reply #12 on: November 19, 2017, 04:28:02 PM »
Nothing.
Also, if you never ask, the answer is always, "no."
If no one is doing it that way, there is a probably a very good reason.
ND6M
« Reply #13 on: November 20, 2017, 05:25:36 AM »
I don't live in an HOA controlled neighborhood,......
Actually, you really better hope that your vertical antenna and mast doesn't fall.
It will hit your neighbors house if it falls in that direction.
17.228.300 Antenna mounted on existing building or structure.
A.         Antenna mounted on existing building or structure—General. Except as provided in subsections B, C, and D of this section, and except for an antenna subject to section 17.228.310 or section 17.228.320, an antenna mounted on an existing building or structure, together with related equipment, is subject to director-level site plan and design review and shall conform to the following development standards:
1.       The antenna, and its related equipment, shall not project above the roof parapet or penthouse roof line of the building, or the highest point of the structure to which the antenna is attached, by more than 12 feet.
« Last Edit: November 20, 2017, 05:44:53 AM by ND6M » Logged
KN6SD
« Reply #14 on: November 20, 2017, 04:27:23 PM »
I am aware of that Sacramento Building Code and I elected to disregard it...
Russ
