Author Topic: ICOM 7100 DIGITAL FT8 MODE INSTALL GUIDE.  (Read 5014 times)
VE6CPS
« on: November 06, 2017, 06:41:33 PM »
Hi everyone,
I searched all over the internet for this information and figured that I would do a quick how-to. The following is how I got my Icom 7100 going on FT8
First install the Icom USB Software from the following:
http://www.icom.co.jp/world/support/download/firm/IC-7600/usb1_20/
Second Install the latest version of WSJT-X from the following:
https://physics.princeton.edu/pulsar/k1jt/wsjtx.html
Here are the radio settings that I used:
Click on the "Set" button
Select "Connectors"
The following are the setting that I am currently using:
Connect your USB cable from the radio to your PC.
Open the WSJT-X program you have downloaded. Here are my radio settings that seem to work well:
Make sure to select the radio "Icom IC-7100" there are other options to make sure that you select the correct radio type!
Those are my settings, hopefully that helps out some others who are looking to get into the FT8 world.
« Reply #1 on: November 08, 2017, 06:18:22 AM »
Set your "split operation" to "fake it"  and you will enjoy the programs ability to adjust your base frequency to keep you transmit audio always in the "sweet spot" of your transmitters passband of around 1500 hz and not roll off when your go to the ends of the audio spectrum. This can be slightly disconcerting when you see your base frequency change while you are transmitting, but never fear, the program is keeping up with things and will return you to where you need to be upon switching to receive.   Trust and enjoy Smiley
Good helpful tutorial.
VE6CPS
« Reply #2 on: November 09, 2017, 07:43:23 AM »
Hey thanks! appreciate the response, I will give that a try
AA2UK
« Reply #3 on: November 09, 2017, 08:11:01 AM »
I've done some testing here and see no advantage in changing one's TX freq as described above, I've also monitored very strong stations not using this "feature" and have yet to see any audio harmonics/ artifacts.
James I'm with AA4PB on this it's mostly nonsense.
Now split operation on 6 meters and up uses this to QSY off of the digital calling frequency. But this entirely different then the above narrative.
Bill, AA2UK
« Reply #4 on: November 09, 2017, 08:30:40 AM »
Bill, AA2UK
Bill, it depends on your transmitter.  Some roll off audio more than others.  As for the harmonics, I believe they are mostly caused by overdriving.  The people I have had the opportunity to help, and eliminate their harmonics was simply a matter of turning down the transmit audio drive so that even with the slider on WSJT-x turned up full, the harmonics are eliminated. I have fixed several over the air and phone.  It is not so easy to fix the ones in Cuba though. Smiley  I will say that the most prolific Cuban operator is clean as a whistle though.
WM4RB
« Reply #5 on: November 20, 2017, 07:43:03 AM »
Great post. It show me what settings I needed to change on my IC-7100. Finally making contacts now. Thanks!
Mike, WM4RB
W8JVP
« Reply #6 on: December 20, 2017, 09:50:20 AM »
How do you set up the Audio?
KG5UN
« Reply #7 on: December 25, 2017, 12:03:54 PM »
I can not keep my rig in USB-D mode.
I set it manually, it transmits then when it unkeys it reverts to USB mode.
Any ideas?
VE6CPS
« Reply #8 on: December 27, 2017, 09:26:08 AM »
Hi all, thank you for all of your input everyone!
Just going to answer a few questions:
"Can not keep my rig in USB-D mode.
Any ideas?"
I dont lol.. I dont seem to have that issue. That may be an Icom question.
"How do you set up the Audio?"
I am using the USB cable at the rear of the radio to connect to my PC. I am not currently using any type of interface box or anything like that as it seems to work perfectly.
Ryan
VE6CPS
« Reply #9 on: December 31, 2017, 12:40:32 PM »
Any ideas?
Just did some playing around. In the software in radio settings, change the "mode" to other options and see what happens.. please report back what worked for you.
W2JWP
« Reply #10 on: Today at 05:38:16 PM »
Thank you!!!
Jack  W2JWP
« Reply #11 on: Today at 06:34:59 PM »
If you rig will not stay in USB-D mode, then check the mode setting in WSJT-x  it should be data/packet.
File>Settings>Radio>Mode data/packet button pressed.
Likely the USB button is pressed.
