Author Topic: Fldigi transmit problem  (Read 1394 times)
N4HAL
« on: November 10, 2017, 03:15:06 AM »
Just did a new install on fldigi. Decodes fine, but cannot get it to transmit. Signal is generated and displays properly and heard as it moved from lower transmit info screen to middle display. If I turn on a u-tube video, that audio does key the transmitter. Have used the ham library option for setup "hamlib" and tried every option I could think of. Also tried the "flrig" option with no results.
Any suggestions? My rig is an Elecraft K-3.
Thanks.
Bill
N4HAL
VA3VF
« Reply #1 on: November 10, 2017, 08:54:59 AM »
Thanks.
Bill
N4HAL
Did you select the right soundcards in FLDIGI? Did you remove the TX attenuation that's applied by default? It starts at 3dB, I think.
N4HAL
« Reply #2 on: November 10, 2017, 10:52:06 AM »
You are the man! The 3db attenuation did it-thanks so much!
Bill
VA3VF
« Reply #3 on: November 10, 2017, 10:53:25 AM »
Bill
Another satisfied customer. LOL
