Author Topic: Help with HTX-212  (Read 1120 times)
K0CBA
« on: September 25, 2001, 02:19:34 PM »
I have need to use the CTCSS decode on the Radio Shack HTX-212.  Problem is it doesn't seem to decode well; receive audio seems to drop out a lot while the person is talking even with a strong signal. I don't have access to a service manual so I was wondering if someone knew how to turn up the decode sensivity or increase CTCSS injection level.  Thanks es 73, Bob
« Reply #1 on: September 26, 2001, 11:21:14 AM »
It sounds to me as though you need to turn DOWN the mic gain
or turn UP the CTCSS level in the radio you are trying to listen to -
the CTCSS is getting covered by the audio.  (If so, the signal is
likely to drop out on voice peaks.)
