Author Topic: SG7900 High SWR Help Needed  (Read 857 times)
N7YV
« on: April 02, 2007, 06:43:17 PM »
Dear Fellow Ham,
Several months ago I bought a used Diamond SG7900 antenna, through one of the online ham swap sites, that was advertised to be in "excellent" condition.  Today I installed it in place of my SG7000 that was working great.
Instead of a S9 signal from the local repeater, I only get an S2 using the SG7900.  Checking the SWR, the SG7900's lowest reading is 1.7:1 at 154 MHz.
The published length of the antenna is 62 inches.  Mine measures 60 inches.  I suspect someone cut the bottom shaft.
I have not been able to locate any published dimensions other than the total length.  Can you please tell me what is the correct installed length of each of the four rods?
Thanks in advance.
73, Roger, N7YV
N2VWW
« Reply #1 on: April 02, 2007, 07:27:54 PM »
Check these links, you may be able to order the parts if needed.
http://www.rfparts.com/diamond/sg7900a.html
http://www.rfparts.com/diamond/pdfdocs/SG7900A%20&%20NMO%20Instructions.pdf
http://www.rfparts.com/diamond/pdfdocs/Parts%20Lists/SG7900andSG7900NMO%20list.pdf
Call or e-mail diamond (RF Parts is the distributor) and I am sure they will help you.
Phone: (770) 614-7443
Monday through Friday ~ 8:30 a.m. to 4:00 p.m. PST
Fax: (770) 614-7480
Mail: 435 So. Pacific Street • San Marcos, CA 92078
E-Mail: diamondantenna@rfparts.com
Gary n2vww
N7YV
« Reply #2 on: April 03, 2007, 08:13:20 AM »
Dear Gary,
Thanks a lot for taking the time to help.
73, Roger, N7YV
