Author Topic: 4:1 current balun  (Read 1169 times)
W6HB
« on: June 27, 2007, 05:21:56 PM »
What do you consider the best 4:1 current balun available for use with a doublet and a transmatch?
W5DXP
« Reply #1 on: June 27, 2007, 07:10:55 PM »
One more question - where does one find a doublet with a 200+j0 ohm impedance?
73, Cecil, w5dxp.com
N7IOH
« Reply #2 on: June 27, 2007, 07:12:48 PM »
I don't know if there has ever been a real test to see who makes the best Balun.  But I can tell you that I would only consider buying a balun from DX Engineering.  I think they make one of the best and they will stand behind it.  They make just about anything you could want and they make the heavy duty stuff for governments and commercial use.  They are happy to answer your questions and they have loads of information on their web site.  Here is a link to their web site.
http://www.dxengineering.com/
     Al, n7ioh
SSB
« Reply #3 on: June 28, 2007, 01:35:52 AM »
I can't help but think that there are loads of hams that think any run of the mill balun can be connected to any load that might vary from 5 ohms to 5000 ohms with or without reactance and everything will magically work like they may want it to.
Hmmmmmmmmm!
Alex.....
NE5C
« Reply #4 on: June 28, 2007, 02:38:48 AM »
I can truthfully report that I've had very good service from the "Radio Works - Model B4-2k" 4:1 Current Balun, I purchased in 1996, well made, Quite Affordable, and very dependable. I believe the newer version is called the B4-2KX, now.
KI4NX
« Reply #5 on: June 28, 2007, 04:46:40 AM »
While no one can complain about a DX balun, why not roll your own? It's not that difficult: ferrite toroid, about 10 feet of #14 or #12 Thermeleze wire and a bit of tape and it's done. There are many designs available and with #14 or #12 wire, it will handle legal limit power.
Ken,
KZ4Y
K0CWO
« Reply #6 on: June 28, 2007, 05:36:16 AM »
A doublet with a 200+j0 ohm impedance from 160-10 would be great Smiley
DX Engineering builds a quality balun.  Here is a link that discusses choosing the correct balun.
http://www.dxengineering.com/TechArticles.asp?ID={3E5220F7-2D0F-45B5-85F7-3B654F804C4F}
KC5JK
« Reply #7 on: July 07, 2007, 04:43:31 PM »
KI4NX has the true ham spirit.  I built a KW balun from an Amidon kit about 25 years ago, and it still serves well today.  I've heard another name as a source for toroids, Fair-rite, but don't know anything about them.
If you buy commercial, whatever you do, avoid any balun that has output leads -- as opposed to terminals -- coming out of a sealed body.  If anything ever happens to the length of one of those, you're sunk.  Hopefully, Palomar changed that design.
