Author Topic: Desinator question  (Read 539 times)
K3PFW
« on: September 13, 2004, 03:36:59 PM »
For those ARES(R) DEC's and EC's that work with government entities (towns, counties, etc) Do you have seperate identifiers assigned for use on non-amateur frequencies, ie the public service frequencies?  For those that operate mobile comm vans, are designators assigned for those vehicles?  This question is from my county Emerg. Ops Dir. as we consider 'identifiers' for ARES entities in the county, that may be operating on non-ham frequencies.
Later, 73
John   K3PFW
ARES (R) DEC
Sussex County DE
N3ZKP
« Reply #1 on: September 13, 2004, 04:22:54 PM »
In my experience (about 40 years worth) of disaster/emergency communications, unit identifiers have been assigned by the agency holding the license for the frequencies being used.
Comm vans can have a single, previously agreed upon, identifier for all law enforcement/public service frequencies or a separate one for each service. There is no hard and fast rule.
Tactical identifiers can also be assigned based upon the particular unit's function: Net Control, Comm Van, etc.
Hope this helps.
Lon
W7WHM
« Reply #2 on: September 13, 2004, 11:18:51 PM »
John...
Our county Emergency Management department issues an Emergency Worker photo ID card after the background check is completed and an application is approved.  This ID card carries an identifying number based on what area (ham, SAR, etc) the person volunteers in - for ham operators it would be HAM plus a three digit number, like HAM021.  The 911 dispatch center/county communications center has a list of IDs so they can keep track of who is on the other end of the radio.  These are not tactical call signs but personal identification used in place of ham call signs when on non-ham frequencies.
Tactical call signs depend on the nature of the event and location of the station/operator.  Our comm van is always identified as "Comm Van", oddly enough.  We only have one so there is no ambiguity.
Wally
W7WHM
KE4SKY
« Reply #3 on: September 20, 2004, 07:08:04 AM »
Lon and Wally have summarized it well.
Designators for volunteer assets using assigned public safety frequencies are up to the Communications Unit Leader.
For RACES we use the following Standard Operating Guide:
Emergency communications use tactical call signs exclusively to call other stations. You don’t contact another station on an emergency net by using their amateur call sign, because if you have a reason to call them on the net, they have a DESIGNATOR.
Mobile station tactical calls are easily distinguished from fixed stations by their FUNCTION, followed by use of a unique DESIGNATOR (alpha or numeric) such as. “SUPPLY ONE. “
Fixed station tactical calls are indicative of a GEOGRAPHIC NAME and FUNCTION. The Incident Command Post for a search operation in the Fort Valley is “Fort Valley Base.”
The tactical call sign “COMMAND” is reserved for the senior public safety official in charge of the incident, i.e. the incident commander.  The only time a RACES operator uses “Command” in their tactical call is when speaking for, by the authority of, and under the direct, real-time supervision of the IC, in immediate hearing range and physical proximity.
If operating a served agency radio which is on a non-amateur frequency, you’ll ID transmissions with the tactical call sign assigned to the operating position by the agency Communication Unity Leader.
Maintaining Logs and Status Boards:
Field Team Leaders use ICS Form 214 to track personnel assignments, locations and tactical call signs.
Individual operators use ICS Form 214a to identify themselves on the station log.  Each duty rotation, such as the operator and logger swapping duties within an operational period, as well as take over by a relief team at the end of an operational period, must also be recorded.
Whenever using an amateur frequency, append your full FCC call sign to the end of your last transmission (or every ten minutes if NCS) and let the other station end with his/hers.
To contact another station always state the called station first, followed by the prowords  “this is”, then your station name. Here are some examples:
Calling a station:
“Team 2, this is SAR Base”
“Fair Oaks Command, this is Brush 21”
The correct response is to identify with YOUR call sign, followed by the prowords “go ahead”:
“Team 2, go ahead”
“Brush 21, go ahead”
To end a contact, use the term “out” - never “clear”.
 Here’s how it sounds:
“SAR Base out”
“Fair Oaks Command out”
“Operations out, WC4VAC” (if operating on amateur frequencies.)
What if you need to call a specific person at a location? Easy:
“Fairfax EOC, this is Fair Oaks Command with contact for Deputy Chief Jones.”
But what if you have a written message to deliver?
Even easier:
“Fairfax EOC, this is Fair Oaks Command with traffic”
(Contrary to what some teach, you don’t identify the recipient of a written message in the call - it will be in the message itself, and there’s no reason to duplicate the information!)
Remember: the only time an amateur call sign is used is when using the amateur frequencies, and then only at the termination of a conversation (emergency conversations rarely - if ever - proceed past the FCC’s 10-minute limit for station identification. If for some reason one does, one must of course ID as required.)
VA RACES Specific Call signs:
When activated and on-station the DRT team designator is used as the tactical call of the Field Team Leader.  Designators are alpha-numeric using the Operational Area, RACES District, and Team Designator.
For instance, the field team leader for the first (or only) team in District Two, (which is in Operational Area “C”) would be designated “Charlie Two Alpha” The field team leader position will usually change with each operational period throughout a lengthy incident, so “Charlie Two Alpha” gives everyone a way to get in touch with the person in charge of a specific team, without having to remember just who that is at any particular time.
WA4MJF
« Reply #4 on: September 21, 2004, 12:53:02 PM »
Here in NC, the clubs get calls for various
places.
For example:
NC4EO  NCDEM EOC
NC4EB  NCEM Western Branch
W4CAP  NC Wing HQ
NC4RC  Red Cross
NC4WC  Wake County EOC
NC4OC  Onslow COunty EOC
Well, you get the idea.
73 de Ronnie
