Author Topic: Is it the computer, or the weather?  (Read 2561 times)
AB8VE
« on: February 08, 2006, 06:31:14 AM »
I recently had to purchase a new computer over the weekend.  My laptop of 4+ years decided to kick the bucket.  In hopes of having it live longer, I bought a desktop.  At the same time, the weather plummeted from average temperatures in the 50's, to an average temperature in the 20's.  I tried to fire up the HF rig for the first time today since buying the new computer.  I have a random length 14 ga.  dipole on the roof.  When I attempted to use my autotuner to tune it up, forget it.  The best SWR I could get was a 3.0.  Is this because of the new computer, or is the antenna frozen, or is it a combination of both?
73's
AB8VE
K0BG
« Reply #1 on: February 08, 2006, 06:42:54 AM »
I'd suspect the it is the way you have the antenna connected. You didn't say where the auto tuner was located, or what the feed line is. While auto couplers typically have a wide matching range, those built in to transceivers have a hard time with anything over 3:1.
If the antenna is coax fed, an auto coupler like an SGC SG237 may indeed match the antenna, the losses through the coax may be very high.
Temperature and humidity have all sorts of effects on antennas, but about the only thing a new computer can do is birdie up the receiver.
More info is needed here.
Alan, KØBG
www.k0bg.com
AB8VE
« Reply #2 on: February 08, 2006, 07:39:13 AM »
I apologize, I suspect I could be slightly more specific.  The antenna is a random length dipole antenna that i built with a coax feed.  I have been using this setup for more than 6 months and it has been working great.  I have worked much DX on it.  The tuner is an LDG Z-100 autotuner.  For those not familiar with it, it uses a system of latching relays.  When the microprocessor finds a match, the relays lock and stay there.  It's really simple to figure out if you have a match.  After a tuning cycle, if you get a solid green light, you have an SWR of 1.5.1 or less.  When it blinks, 2.1 or less.  No green light?  No match.  This morning, the green light was blinking very fast which makes me think that it was between 2.1 and 3.1.  I didn't disconnect the radio in any way when I installed the new computer.  The desk has a higher platform for the monitor to set on.  The only thing i changed about the radio setup is I moved the tuner from the lower part of the desk to up next to the monitor to accomodate the computer speakers.
K7UNZ
« Reply #3 on: February 08, 2006, 09:49:44 AM »
It is possible that you are getting RFI from the monitor into the tuner control circuits.  Just move the tuner away from the monitor and see what happens.
Jim/k7unz
« Reply #4 on: February 08, 2006, 01:43:34 PM »
It's the phase of the moon.
When the moon is in the Seventh House, and Jupiter aligns with Mars, then Peace and Love will guide your antenna tuner.
I think there was even a song about that...
Actually, although anything's possible I really doubt it's "the computer."
More likely something changed with the antenna.  You sure you don't have ice bridging any part of the antenna to your roof, or something like that?  Physical changes, including the presence of ice, can make big changes in the way antennas load but I've never seen a monitor influence an antenna tuner.
AB8VE
« Reply #5 on: February 08, 2006, 04:38:55 PM »
Thanks for the help guys!  Actually as the day progressed, and the sun rose, I tried it again, and there was no problem.  It took some time to get 17 meters to tune up, but 20 tuned up just like normal.  The antenna was just frozed or something.  Thanks for the clarification though!
AB8VE
K7UNZ
« Reply #6 on: February 08, 2006, 05:54:00 PM »
Actually Steve, some of the older LDG models are very sensitive to, and even generate their own, emi/rfi, and depending on how well the computer system is shielded, it can cause problems.  Have a friend who literally threw away his LDG due to that.
On one model LDG even tells you in their manual that if the tuner is causing receiver hash problems, turn off the tuner lcd bargraph display. Don't know what good the tuner is without the SWR/power display operating...hi!
I currently have two LDG tuners, the AT-100Pro, and the AT-1000, and haven't had a problem with either.
Strange things do happen......
Jim/k7unz
K0BG
« Reply #7 on: February 09, 2006, 06:27:08 AM »
As Steve Katz said, it could be the moon phase. One of the problems is simply the way you feed your antenna. There is great loss in the coax on any frequency removed from it's resonant point. In fact, two things can happen.
First, the RF voltages can exceed the breakdown voltage of the coax even with just 100 watts of RF.This fact could also be the cause of your problem. Secondly, the amount of RF lost due to the very high SWR could be nearly 100%!
When using coax, the place for the auto coupler is at the antenna. You would need an RT11 or one of the SGC models that is weatherproof. Or, buy the balun LDG makes to go with the coupler and feed the antenna with ladder line.
Alan, KØBG
www.k0bg.com
WILLY
« Reply #8 on: February 11, 2006, 04:38:49 PM »
 by WB2WIK on February 8, 2006
When the moon is in the Seventh House, and Jupiter aligns with Mars, then Peace and Love will guide your antenna tuner. "
No, no, no -
It's  "Then peace will guide the planets, and love will
steer your EME array."   Smiley
"I think there was even a song about that...  "
Aquarius (or Age of Aquarius - can't remember for sure)
-   Fifth Dimension  ,  circa late '60s.
You're dating yourself.    And <ahem>, I'm not.   Smiley
W8DPC
« Reply #9 on: February 20, 2006, 02:17:14 PM »
Might be easiest to reach over and turn the computer off, and see if the problem persists.
