Author Topic: Pro-III, RX antenna  (Read 1379 times)
WW5AA
« on: August 14, 2007, 08:17:12 AM »
I have been using a homebrew RF sense switch for several years to switch between my TX and RX antennas. When RF is applied the switch grounds my receive antenna and switches the pre-amp to the through position. I have never used the RX antenna connector on the Pro III. The manual does not have a lot of information (or I’m not finding it) on the RX antenna connector. The question is:
1. Does the Pro III ground the RX antenna when transmitting?
2. How much attenuation can I expect?
Thanks for any help.
73, de Lindy
« Reply #1 on: August 14, 2007, 04:51:46 PM »
It doesn't ground it but it is disconnected from the receiver input during transmit. It's designed to function with a separate receive antenna on HF (typically for a beverage or other low noise receive antenna for 160/80M). According to the block diagram it bypasses the normal T/R section + tuner and has its own high pass filter.
WW5AA
« Reply #2 on: August 15, 2007, 07:20:55 AM »
Thank you Bob ...just what I needed.
73, de Lindy
