Author Topic: PYRAMID POWER SUPPLY  (Read 1399 times)
AE4TR
« on: March 12, 2008, 06:10:12 AM »
Hello to all.  I have a PYRAMID model PS-36KX that the voltage meter has died and need to replace it.
 Does anyone know where to get Pyramid parts for their power supplies... google search does no good, all it lists are new or used, complete units, no parts.
  PYRAMID support is nonexistant also.
  I have the flimsy little booklet that came with it
  and the schematic is very small, and has no parts list.
  I think that I shall never buy anything else from
 Pyramid, especially power supplies..
  Thank You, Ben...AE4TR
N8UZE
« Reply #1 on: March 12, 2008, 06:27:43 AM »
Is this a digital meter or an analog meter? If it is the latter, these are so simple that there isn't much to fail in the meter itself.  I'd suggest checking the lines and connections that go to the meter.  There may be a solder joint that gave up or some corrosion, etc.
W3LK
« Reply #2 on: March 12, 2008, 10:48:36 AM »
Been drinking too much Dew? <g>
Lon - W3LK
Naugatuck, Connecticut
AE4TR
« Reply #3 on: March 12, 2008, 12:32:08 PM »
It's analog.. not much to go wrong you say!  Yep that's correct. Not much but the meter it's self.
When there is no movement at all and with my trusty
digital fluke meter, I measure voltage on the pins at the back of it, then the only conclusion is that the meter is bad..
Any more bright ideas?
