Author Topic: 01 Nissan Maxima - pwr supply cable thru firewall  (Read 1305 times)
KD7TCV
« on: February 16, 2004, 01:28:13 PM »
Does anyone have any suggestions on a good location to pass the power supply cable from the battery thru the firewall?  Thanks in advance.
K4KWH
« Reply #1 on: February 17, 2004, 02:22:11 PM »
Remove the foot plate, or threshold under the door. You may find a hole already drilled, or you can drill one under there AFTER making certain no other obstructions exist.  You can use silicone caulk or
rubber grommets (Radio Shack) to keep water out. Replace the threshold cover and no one is the wiser.
Take the wires up along the frame rails up into the
engine compartment. Use wire ties to keep the wires
neat and out of the way. Make sure you route them away from the engine manifold (hot) or where they may
rub against the wheels. This is easier than trying to
get into the firewall and/or risking drilling into something you'd regret (UH OH!)
www.qsl.net/k4kwh
KC7WSU
« Reply #2 on: May 02, 2005, 03:03:22 PM »
I have a 2000 nissan maxima and I am wondering if you found a way to go through the fire wall?  the 2000 is the same body style, just that the 2001 has a few upgrades.
Chris
KC7WSU
