Author Topic: Yaesu FT-90R will not rx outside ham bands...  (Read 213 times)
KE4WLE
« on: February 19, 2007, 04:49:54 PM »
Somehow i've enabled an iption on my ft-90R that prevents me from being able to rx outside of the 2M ham band.  It TXs just fine inside the band as expected.
What option did I enable that caused this and how can I fix it?
N5EAT
« Reply #1 on: February 20, 2007, 11:49:17 AM »
Why do you want to transmit outside of the ham bands?
KE4WLE
« Reply #2 on: February 20, 2007, 04:37:29 PM »
I don't.
Inside the 2M ham band it does both rx and tx just fine.  However, the unit for some reason will not let me tune outside of the 2M band to allow rx as it should (for example, it will not let me tune to the wx and aviation frequencies, as it shuold, and used to let me do.)
AA4TX
« Reply #3 on: February 21, 2007, 05:28:49 AM »
I understood him to ask about RX, not TX.
Have you tried reseting the CPU? to accomplish this, you have two options:
(1) To reset all MENU settings to their factory defaults, press and hold in the "SET" key and the "DISP" button while turning the transceiver on. This procedure does not alter or erase any channel memories you may have stored.
(2) To perform a CPU master reset for all memories and MENU settings, press and hold in the "<-" key, the "->" key, and the "DISP" button while turning the transceiver on.
(Page 50 of the manual)
KI4LTX
KE4WLE
« Reply #4 on: March 02, 2007, 04:30:00 AM »
Thanks KI4LTX!
Option #2 fixed it!
KE4WLE
