Author Topic: Yaesu FT-2800M tones from mic?  (Read 1222 times)
KB3POY
« on: November 04, 2007, 06:26:33 AM »
How do I generate TONES with the microphone?  I can enter frequencies just fine, but when I have the PTT enabled and try to enter tones for repeater commands, I get n tones.
« Reply #1 on: November 05, 2007, 06:05:46 AM »
I don't have one of those, but if it is like the Icom 7000, you have to store the "tones" in memory.
Alan, KØBG
www.k0bg.com
KG4RUL
« Reply #2 on: November 05, 2007, 08:20:47 AM »
I am assuming that your radio was supplied with the MH-48 DTMF Microphone.  Make sure that that Menu Option 08 DTMF is OFF to disable the DTMF Autodialer function. If the function is enabled and you press a Numeric button, the radio would try to send the tones stored in that DTMF Autodialer memory position.  If there are no tones stored, nothing happens.  With the function disabled, the Numeric buttons send the appropriate tone when pressed.
K3DC
« Reply #3 on: December 23, 2007, 08:24:58 PM »
I had similar problem.  When I pressed PTT the first row of buttons would not send tones.  1,2,3,A would not.  All others would.  Very strange.  I had to reset to factory to correct this behavior.  When I contacted Yaesu about it I was told that it was a "cpu glitch" and I needed to reset the radio.
Chris,
KI4YMD
