Author Topic: Using RG-58 as a DC Line  (Read 2176 times)
« Reply #15 on: March 31, 2009, 06:43:25 AM »
Take a 10 foot piece of good quality RG8, and put a load of 20 amps on it at 13.8 volts, and measure the voltage drop. The results speak for themselves.
Alan, KØBG
www.k0bg.com
« Reply #16 on: March 31, 2009, 06:44:51 AM »
The bottom line is that there is no good technical reason to use coax for the +12V DC power line. You can get the appropriate size 2-conductor (red/black) power cable at nearly any automotive supply store. The insulation is better suited for the temperatures likely to be encountered in the engine compartment and is less susceptible to abrasion and damage by oil or other fluids that might get on it.
« Reply #17 on: March 31, 2009, 09:29:48 PM »
K0BG: I stand corrected the total resistance of 1' of RG-213 is 3.2 m ohms. A 10' length has a resistance of 32 m ohms. 20 amps gives a voltage drop of 0.64 volts.
Link to the datasheet:
http://www.romkatel.ro/cataloage/pdf/eupen/RG213.pdf
