Author Topic: External vs built-in tuner  (Read 3654 times)
KB4OIF
« Reply #15 on: July 23, 2010, 03:00:19 AM »
Like many have already said, it depends on what type of antenna you plan to use.  The suggestion about getting both if you can is a wise decision. Down the road in your journey in the hobby, you Will accumilate a lot of stuff.  If you are using a fairly resonant antenna, the internal tuner will work.  If not, get you a Good external one. Eham has an extentsive amount of info from hams from all over with reviews of almost any item in this hobby of ours.  Do the research, it will give you the info you need.
