Author Topic: Read the FREQ. from a FT-990 using VB6  (Read 2127 times)
AA8R
« on: November 13, 2004, 11:08:37 AM »
I'm a rookie at VB6 and I am trying to read the freq. from my Yaesu FT-990.  I can set the freq. or change mode or filters, etc. with no problems.  Just can't seem to get the right syntax for reading the freq. Can anyone help out with this? I'm using Yaesu's FIF-232C CAT system as an interface between the PC's COM port ant the 990.  Following is the logic that I'v tried:
Private Sub Form_Load()
Dim buffer As String
Dim i As Integer
Dim mdata(1500) As String
MSComm1.CommPort = 1
MSComm1.Settings = "4800,N,8,2"
MSComm1.InputLen = 1500
MSComm1.PortOpen = True
MSComm1.Output = Chr$(0) & Chr$(0) & Chr$(0) & Chr$(0) & Chr$(16) ' read update
buffer = MSComm1.Input
For i = 1 To 1500
  mdata(i) = Mid(Asc(buffer), i, 1)
 Next i
Randy - AA8R
AA8R@AOL.COM
AA6YQ
« Reply #1 on: November 17, 2004, 11:52:18 PM »
Requesting a 1508-byte status block will prevent you from smoothly following the FT-990's frequency as its QSYs. There's a ROM update that enables the FT-990 to respond with a 16-byte status block containing the VFO frequency, clarifier setting, and mode. The appropriate command to send is
Chr$(0) + Chr$(0) + Chr$(0) + Chr$(2) + Chr$(16)
Here's code that parses the resulting 16-byte status block in RcvBuffer(1) through RcvBuffer(16) :
                                             FlagDigit = RcvBuffer(5)
RXClar = (FlagDigit And 2) = 2
ClarifierDigits = (RcvBuffer(6) * 256#) + RcvBuffer(7)
If ClarifierDigits > 32768 Then
    ClarifierDigits = -(65536 - ClarifierDigits)
End If
Clarifier = ClarifierDigits / 1000
FreqDigits = 0
For I = 2 To 4
    FreqDigits = (FreqDigits * 256) + RcvBuffer(I)
Next I
NewFreq = (FreqDigits / 100)
If RXClar Then
    UpdateRadioFreq (NewFreq + Clarifier)
Else
    UpdateRadioFreq (NewFreq)
End If
ModeDigit = RcvBuffer(Cool
Mode = GetModeFromYaesuFT990Status(ModeDigit)
        Dave, AA6YQ
