Author Topic: TX4T  (Read 1773 times)
WB6RXG
« on: February 23, 2010, 11:17:13 AM »
I've heard TX4T on 1.832 Mhz the last two nights at around 10:30pm PST (0630 GMT/UTC) at S9+ on my 80 ft vertical and TS-2000.  The first night he was sending CQ TX4T QRX 25.  On the second night he was sending CQ EU TX4T QRX 25 EU K.
I haven't made a CW contact in over 30 years due to being inactive for most of that time and I've never been a DX chaser.
My question is what did he mean by QRX 25, is he listening 2.5 khz up, 25 khz up or on 1.825?
Stuart
WB6RXG
WB6RXG
« Reply #1 on: February 23, 2010, 12:12:23 PM »
I typoed that.  I mean't QSX 25.
Stuart
N3OX
« Reply #2 on: February 23, 2010, 01:02:39 PM »
In this case he meant 1825.
I would say that usually if the number is bigger than about 5 or maybe 10 in a stupid pileup, and the "frequency interpretation" makes sense given the band plan, you should go with that interpretation.  I also think that "QSX 25" absolutely means they're listening on a frequency that ends in "25."  "UP 25" and "DN 25" are more ambiguous.
That said, one of my favorite DX moments was getting a DXPedition on 30m by one of the few people who caught the sudden switch to "UP 17," which was indeed up 17kHz.  VP6DX also kicked off their operation by calling CQ on 7002 with an "UP 25" that meant 7027.  Man, that was some ferocious dial spinning...
But I've also heard  "UP 25" to mean "UP, listening on 7025"
So to a certain extent if it's "UP" or "DN" and a big number, you just have to guess right or find the pileup.
Dan
Dan
http://www.n3ox.net
« Reply #3 on: February 23, 2010, 02:13:05 PM »
You transmit on 1825 kHz. He transmits on 1831.5 kHz. When he says EU don't answer unless you are in Europe.
TX4T comes in quite well almost every night on 160 meters, so don't panic thinking this is a one time thing. Check the eham.net DX Cluster Spots (look to the left) to see when he is on. He is always on 1831.5 kHz when he's on the air.
160 meters has been good this season. I can work Europe from Utah running a 20 x 20 ft inverted-L. A fun band for sure.
WB6RXG
« Reply #4 on: February 23, 2010, 03:31:08 PM »
Thanks for clarifying that.
I've never actually copied a DX station on CW before and was suprised when I did.  My copy speed must be improving.  He wasn't making any contacts so there wasn't a pile up to listen for.
Stuart
WB6RXG
N3OX
« Reply #5 on: February 23, 2010, 05:14:08 PM »
Yeah, I think they've worked down the U.S. demand to a certain extent (I made a contact nearly two weeks ago)
The European guys couldn't hear TX4T much if at all last night.
Dan
http://www.n3ox.net
K5TN
« Reply #6 on: February 24, 2010, 01:31:00 PM »
Stuart---
Methinks if I had access to an 80 foot vertical, I'd be on 160 when the sun went down....every night!!
Wade  K5TN
