Author Topic: DigiPan  (Read 1945 times)
VE9FP
« on: September 19, 2007, 05:10:44 AM »
I am using DigiPan and Tigertronics SL-1 USB interface.The system works ok except that I used to see the signal on the waterfall in yellow color and now it is blue . This is the same clolor as the waterfall and is hard to see . How can I correct this?
VE9FP
« Reply #1 on: September 19, 2007, 01:07:53 PM »
I am on PSK 31 mode using Digipan software and Tigertronics SL1+ USB interface. In the past I received the signals on the waterfall in Yellow color. It is now green which is practically the same color as the waterfall background. I cannot see the signals very well. I do not not why this happended and I would like to know what to do to get the yellow color again
VE9FP
Email: ve9fp@rogers.com
KE4DRN
« Reply #2 on: September 19, 2007, 02:45:25 PM »
hi Francis,
Select configure from the toolbar,
then select colors.
You can reset to default or any color you like.
73 james
WI7B
« Reply #3 on: November 29, 2007, 02:53:04 PM »
In general, if you have not changed the color settings, the change in color is a reflection of singal strength that Digipan receives.
Have you adjusted you line-in signal levels? Your antenna, or the rig's audio output levels?
---* Ken
