Author Topic: Counterpoise  (Read 796 times)
NR6K
« on: September 08, 2010, 04:44:11 PM »
I am getting ready to install my counterpoise radial system on my flag pole vertical antenna.
The first question is what gauge wire to use?
The second question is why not hook up the metal floor frame of my mobile home as part of the counterpoise?
W8JI
« Reply #1 on: September 08, 2010, 05:30:36 PM »
Use big enough wire to mechanically stay intact. Electrically almost anything will work.
Depends. Are you using an elevated resonant counterpoise? If so, don't use the frame.
« Reply #2 on: September 08, 2010, 05:40:45 PM »
The wire has to be stong enough to not break.
If you bury it underground even #20AWG will usually be okay as it's protected.  Above ground, something stronger is better if people are walking on it.
Let's hear you on the air!  Can you get on this evening?
W7ETA
« Reply #3 on: September 08, 2010, 09:30:33 PM »
W4RNL's site has good info on counterpoise and radials.
Bob
N8CMQ
« Reply #4 on: September 09, 2010, 12:12:33 AM »
I used 20 gage copper plated steel wire feed welding wire. I bought a big spool of it and laid out 125 radials 30 to 36 feet long (BIG spool of wire!). I also soldered the wire into a crimp ring terminal with six wires per terminal, after putting in the six wires, I would crimp, then solder the terminal. You can see it on my blog, if you are interested, it is on my space, under N8CMQ.
W8JI
« Reply #5 on: September 09, 2010, 03:43:57 AM »
In a few years that wire will falling apart.
Welding wire is not copper plated. It is a light copper flash that almost rubs off. It typically lasts about a year or less in open air, let alone in contact with soil.
KH6DC
« Reply #6 on: September 09, 2010, 09:45:30 AM »
I used 14 gauge copper stranded wire I bought from Home Depot.
