Author Topic: Digipan and IC-718  (Read 2786 times)
MOTOR486
« on: February 17, 2011, 04:48:20 AM »
  I'm trying to configure Digipan 2.0 to run with my Icom 718. There is no IC-718 listed on the list of Icom radios when I try to configure.  What is the equivalent radio that I should select from the list?  Thanks.
Rob Frailing
AJ4SB
KC7CRR
« Reply #1 on: February 17, 2011, 12:41:01 PM »
Rob,
Comments sent via "your call@arrl.net"
KC7CRR
MOTOR486
« Reply #2 on: February 17, 2011, 01:13:11 PM »
Thanks, Bob
G0GQK
« Reply #3 on: February 17, 2011, 01:51:51 PM »
The important thing to know is what software you are using. If its XP that's OK or Vista is a maybe sometimes, but Windows 7 it won't work. Digipan was designed for Windows 95 and that was a long time ago !
G0GQK
VA7CPC
« Reply #4 on: February 19, 2011, 04:21:16 AM »
Funny - I'm running Windows 7 with Digipan.
I may have either (a) changed the "installation directory", or (b) made my "Program Files" directory read/write (instead of the default "read-only").
But my question is:
. . . Why do you need rig control with Digipan and PSK31 ?
You tune the rig to 14.070 USB (maybe up or down a kilohertz) and leave it there.
              Charles
