Author Topic: How does the IC-7401 compare to the TS-590 on paper?  (Read 1130 times)
ZR1PJA
« on: April 15, 2011, 01:34:40 PM »
I am pretty much a black box operator and don't understand how all the numbers work, but I am looking at a rig that will that can clear up a received signal very well. I am not interested in purchasing top of the line rigs as I cannot justify that expense.
The two above mentioned rigs are new in the market and the IC-7410 is not yet around, so would like to know what can be expected when comparing the two rigs.
Thanks
VA7CPC
« Reply #1 on: April 15, 2011, 02:17:57 PM »
A review of the TS-590 is in the newest QST.  The reviewer likes it -- "good bang for the buck" -- which, at $1800 list, should be a whole lot of bang.
If the IC-7401 isn't out yet, it's hard to predict how it will compare to anything.
What antenna do you have?  What do you want to do?  Do you have a ham a half-mile away with a 1 KW amp?
                       Charles
N3WAK
« Reply #2 on: April 15, 2011, 02:28:40 PM »
Paul--I am not familiar with these rigs, but I do recommend the ARRL Handbook and the RSGB Radio Communications Handbook as two good references.  They help to explain signal-to-noise ratios, receiver sensitivity and selectivity, etc, and are a good foundation for your shack bookshelf.  73, Tony N3WAK
M6GOM
« Reply #3 on: April 15, 2011, 03:16:42 PM »
Out of the box, the TS590 absolutely canes the 7410 on receive. The narrowest filter on the 7410 is a 3kHz one which must be purchased in addition to the radio whereas the 590 comes with a 2.7kHz and 500Hz one as standard.
