Author Topic: Yaesu FT-990 Fan Problems  (Read 7289 times)
N5AS
« on: April 24, 2011, 03:22:44 PM »
The fan on my FT-990 cycles normally, but starts out at slow speed with noise and finally reaches full speed after about 10-15 seconds.  I have it out on the bench and runs with a cogging noise, for lack of a better description, and never reaches full speed.  Are the motors repairable or do I have to buy a new fan?  It doesn't look like a normal fan motor to me.   Tom, N5AS
AC5UP
« Reply #1 on: April 24, 2011, 03:39:47 PM »
Considering the rig is approaching 20 years old I have a hunch a little bit of oil wouldn't hurt the fan...
I have never seen one, but if it's anything like a 12 volt brushless DC computer fan there will be a label on one side with an indentation under the label you can feel. Poke a hole in the label and peel it back enough to push some oil through the hole. Take your time. Exercise the fan, give it a little more oil, if and when it feels like it's moving more freely consider that Mission Accomplished.
Smooth the label back as best you can. If a tab of PVC tape feels like a good idea use one to reduce the chances of dust getting into the spindle.
Some days you're Batman, some days you're The Joker.......
N5AS
« Reply #2 on: April 24, 2011, 03:53:16 PM »
This fan is a squirrel cage type 6 inch's long and about 1-1/2 inches in diameter.  It's not a bearing noise, more like an electrical.  Fan turns freely too.
« Reply #3 on: April 24, 2011, 04:12:46 PM »
Bearings are going dry. A few drops of oil in right place should fix it. The noise is from bearing until it warms up enough to melt what little lube is left. I have revived many fan motors this way. Synthetic motor oil (5w30) seems to last longest.
Ham since 1969....  Old School 20 WPM Extra
K7ZRZ
« Reply #4 on: April 24, 2011, 04:42:03 PM »
Tom,
I've had the fan out of my FT-1000d, which I know to be the same type. The "detent-ness" that you feel when you spin the fan is the magnets of the stator and rotor passing each other.  I'm sure the suggestion of lubricating is right on. The only thing that touches in there are the bearing points, and you should lubricate them the best you can.
Brian K7ZRZ
N5AS
« Reply #5 on: April 25, 2011, 04:56:46 AM »
Oiled fan bearings, no help.  Noise is direct from motor and still not coming up to speed. New fan (motor) may be the issue.  Thanks for the replies.  Tom
KE3WD
« Reply #6 on: April 25, 2011, 06:47:02 AM »
If this is a DC powered fan motor, good idea to check the line to it for any AC ripple before blanket ordering up a new fan.  Might just be a case where a filter cap or perhaps a regulator is what is really on the fritz, especially considering that it only exhibits the noise at the lowest speed setting.
N5AS
« Reply #7 on: April 25, 2011, 07:41:48 AM »
It is running slow on a 12V bench supply too.
« Reply #8 on: April 25, 2011, 09:03:30 AM »
Any way to get it apart or blow it out with canned air?  If you can get it apart, check any spacers at the ends of the shaft.  If they're worn it's possible the rotor is rubbing the bearing housing.
K7ZRZ
« Reply #9 on: April 25, 2011, 01:58:08 PM »
Tom,
If you can come up with a part number, you should first call Yaesu - parts department and give them the part number. Chances are they will have that part still in stock. Just asking about parts for an FT-990 will likely get you a "no longer stock those parts" as a thoughtless response.  That's a common story, but you'd be surprised what they still have available if you can give them a part number to look up.
Brian K7ZRZ
VK6ABM
« Reply #10 on: April 27, 2011, 12:44:05 AM »
Tom
While I have not seen the motor I have assisted a VK4 in fixing that same fault by replacing a 1uF 50volt electrolytic on the motor pcb
I don't have the schematic of the motor pcb so don't know for sure what the capacitor does (could be a ramp timer) but from descriptions the motor is a stepper type - wonder if you do get into that area maybe you could take a closeup photo of the board - I am keen to know all about it (the VK did not have a camera)
Brian
N5AS
« Reply #11 on: April 27, 2011, 05:37:57 AM »
The fan is running at normal speed now and no cogging noise either, after a little clock oil in the bearings  Grin.  Even though the fan rotated freely with some duration the oil must have been needed anyway.  Thanks for all you help and input.  Tom
