Author Topic: FT-101EE CW Filter Help, Please  (Read 3733 times)
AA4DF
« on: April 22, 2003, 04:04:01 PM »
Yipee! I finally got a CW filter for my trusty ol' FT-101EE! I thought it would be like the TS-820S with an obvious jumper across the filter area of the PCB, but it's not. Can anyone tell me where the FT-101EE is jumpered to pass through the SSB filter with the switch in CW mode? In other words, what must I change for the transceiver to "see" the CW filter in CW mode? I have no manual for it. Thanks in advance for any help & 73 to all.
KB3IMY
« Reply #1 on: April 25, 2003, 08:15:05 AM »
Here is a link that has a manual in PDF format for your radio.
http://www.mods.dk/index.htm
When you get there, click on Yaesu, then click on manuals.
Mike
KF6IIU
« Reply #2 on: June 07, 2003, 07:34:12 PM »
On the FT-101E it's on the PB-1183B board right above the SSB filter. You clip off a coupling capacitor and install the CW filter in place. It's pretty clear to me where it goes, there should be a big blank spot on the board. You have to take PB-1315A out first. (This is from FT-101 instructions.)
!! - Don't confuse the SSB filter in the speech processor with the main IF filter! The speech processor filter is mounted horizontally right on the top of the system. The IF board is mounted vertically over on the left side of the unit.
