Pages: [1] 2 3 Next   Go Down
Author Topic: Magnum257HP  (Read 27555 times)
WB9YCJ
« on: October 03, 2011, 09:07:44 PM »
How accurate is the frequency display on the new Magnum 257HP in SSB mode ?
In other words, does the display say 28.400 when talking to hams on that freq?
Im considering buying one but not if the display is inaccurate on SSB mode.
I know $200 doesnt buy alot.
Thanks, in advance
Ken
« Last Edit: October 03, 2011, 09:10:19 PM by WB9YCJ » Logged
W8JI
« Reply #1 on: October 04, 2011, 02:59:02 AM »
Thanks, in advance
Ken
I'd worry about the bandwidth of the transmitter in that radio. It's not well desiged, and does not even use real linear RF transistors.
ZENKI
« Reply #2 on: October 06, 2011, 02:03:54 AM »
Its CB junk lets get that straight first.
It has a 100hz display. 100hz display radios were last seen on ham radios in the 80's thats how crap it is. Most radios today have a 10hz display and have very good accuracy.  The tuning resolution on this radio will also be poor compared to a cheap DDS  ham radio. Even the cheapest mobile radios like the FT857 comes TCXO which  basically means that  a radio like FT857 will  have much better stability.  All the low end cheap ham radios models have better receivers and stability than this CB junk.
The worst thing about this radio and models like it is that they cause a lot of splatter. Why any ham would  buy this junk today and think they buying something good is beyond me. All I cant say is keep this splattering junk off the ham bands.
Thanks, in advance
Ken
N3WAK
« Reply #3 on: October 06, 2011, 04:54:03 AM »
Ken--You'll note that in his posts, Zenki never--even when prompted--gives a callsign.  (The other guy who does this is "OnAir.")  I am always skeptical of anonymous posts--people can say whatever they want behind the cloak of anonymity.  W8JI though, IS an expert and well-respected throughout the ham community.
I have a Magnum 257 HP as one of many radios.  I haven't used it much but I like it--but I bought it knowing its limitations, and it's not my only rig.  I bought it for a radio to use sitting out in the backyard in the summer.  If you don't have a rig yet, I'd get a multiband ham radio, either new or used.  It will be a better radio and much more versatile.
Good luck.  73, Tony N3WAK
MAGNUM257
« Reply #4 on: October 06, 2011, 08:31:40 AM »
I have one of these radios also. I'd say the performance is just what you would expect from a $200 radio. For me it fills a need in a vehicle that is only used occasionally, so price was the main deciding factor when it was purchased.
ck
BOOTYMONSTER
« Reply #5 on: October 06, 2011, 08:46:50 AM »
http://www.cbradiomagazine.com/Radio%20Reviews/Magnum%20257%20HP/Magnum%20257%20HP.htm
KB1TXK
« Reply #6 on: October 06, 2011, 11:10:17 AM »
Thats a hacked/rebranded RS HTX-10
HTX-10: http://files.qrz.com/v/kd0giv/radioshack_htx10.jpg
Magnum: http://www.rrcom.com/pictures/mag257blue.jpg
And HTX-10s are under $100 hahahaha
KB1TXK
« Reply #7 on: October 06, 2011, 11:14:35 AM »
Unless they completely gut the HTX-10 and replace all of the internals, which I'm sure they haven't....you're very wrong on all accounts.
EDIT: In my humble non-technical opinion. All I know is...I will NOT be removing my perfectly good HTX from the ham bands
« Last Edit: October 06, 2011, 11:22:35 AM by KB1TXK » Logged
W8JI
« Reply #8 on: October 07, 2011, 12:52:16 PM »
Here's where the CB stuff shows up.
The HTX-10 is a 25 watt PEP rating, and uses two 2SC1969 SSB output transistors with actual ratings for linear PA service.
Now we have the "same radio", sold as an illegal CB radio, suddenly rated at 80 watts. It uses a transistor that has no traceable SSB specs in data sheets and has an odd custom house number. The data sheets for the PA device in the Magnum are nonsense.
How anyone equates the two systems is puzzling.
KB1TXK
« Reply #9 on: October 07, 2011, 12:56:44 PM »
Well there...I learned something today. Smiley
I equated the two because they use the same case, knobs/buttons, displays, etc (different color I know).  I'm not technical enough to be able to look at schematics and not want to pass out...so thank you for setting me straight!
W8JI
« Reply #10 on: October 07, 2011, 01:05:46 PM »
This is how the Ham bands will eventually be ruined or damaged significantly. We start to believe what people selling illegal radios tell us.
KB1TXK
« Reply #11 on: October 07, 2011, 01:08:51 PM »
Well for the record...I made those terrible assumptions all on my own, based entirely on what Google images was showing me.
That said, I probably shouldnt have admitted that....
WB9YCJ
« Reply #12 on: October 08, 2011, 05:23:04 AM »
My question still is unanswered:
Does the freq display say 28.400 when you are actually on 28.400.000 ?
Does the freq display say 28.400  when you are actually on 28.399.674 ?
Best I have seen is it does NOT have a 100 Hz display.  Perhaps having a 100 Hz display would make the freq display inaccuracy very OBVIOUS.
YES, it is possible for a good radio to say 28.400 when its actually tuned in on 28.400 (even though there is not a hundreth or ten Hz display digit). When I have a local net on 28.400 , can I dial up 28.400 on the radio's display and hear stations natural sounding and tuned in properly or will they sound 300 or 400 Hz off freq like donald duck?
My guess is that the display is not highly accurate.
I acknowledge the side comments provided.
Perhaps I have to buy or borrow one to find out.
Ken
K2OWK
« Reply #13 on: October 08, 2011, 02:51:21 PM »
Hello WB9YCJ, while I am not familiar with the Magnum radio. I did have a while back a Yaesu FRG-7000 which was Yaesu's firest digital readout receiver. Like the radio you are asking about it read to 6 places 28.400 with an accuracy of +/- one digit. so if you set if for 28.400 it could read 28.401 or 28.399 in its worst case. It was a great receiver triple conversion and such. I used my transmitter to set the frequency when operating. I checked the accuracy of the receiver with a frequency counter that read to 9 digits. At 72.000 (40 meters the frequency I used most) the receivers actual frequency as read on the counter was 72.0001020. Pretty accurate I would say. I have found that most digital counters used on radio equipment are very accurate to the number of places it reads, unless there is a malfunction in the counter circuit. If you are interested in checking your frequency accuracy get hold of an accurate counter and check it. The other way is to make a contact on 10 meters and ask the frequency they are reading you at. I did this many times with my original set up, and just about everyone I talked to gave me a check to 8 places. I would not worry to much about the readout accuracy, because when you hear someone calling you will zero beat them and return the call. If you are calling the person hearing you will zero beat your frequency. The only time I would worry is if your frequency was so far off the it caused you to operate outside the band limits, but from your post it sounds like you are just looking to see how accurate you frequency is.
Hope this helps a little.
73s
K2OWK
ZENKI
« Reply #14 on: October 08, 2011, 03:14:38 PM »
Having a callsign does not change the radios TX IMD performance! You can have have your skepticism for anything in life, unfortunately your skepticism does not make your MAGNUM radio any better than it is. The point is that when you measure any of the CB  regardless of what brand it is,(most come from the same factory) they are  terrible performing transmitters on the ham bands. Whats worst is that these same companies who want to promote these radios as legal ham radios have no  hesitation selling these radios with the ham bands enabled in ASIA and the Pacific. Next time you speak to a VK, ZL VR, HS  hams ask them what 10 and 12 meters sounds like during the day! Its jammed with  crud  and illegal pirate stations using these radios right from 24mhz to 30 mhz.  Unfortunately it is your non ethical attitude in buying this junk that is contributing directly to destroying 10 and 12 meters. This is before we even start talking about the raspy splatter that  is ruining other hams enjoyment of the  bands like 10 meters. If you enjoy crapping in your own house, and at the same time destroying other peoples enjoyment of the hobby just to make your favorite CB toy look good so be it, we know where you stand!
Pages: [1] 2 3 Next   Go Up
