Author Topic: Scorpion SA-680S Assistance Needed  (Read 6659 times)
« Reply #15 on: October 18, 2011, 05:24:40 PM »
These are available if you look around http://www.k0bg.com/images/antenna/18407.jpg
GOLDTR8
« Reply #16 on: October 23, 2011, 06:24:30 AM »
Anybody have any Antenna mount designs for my Scorpion Antenna?  I have already been in contact with REP Designs and they did not quite have what I need to be able to mount this antenna to the front bumper the way Ron at Scorpion Antennas suggested.  Any other Ideas?
Look me up on qrz and send me an email and I can help you with pics of my mount.  KD8NNU
Jeeps can be a real hassle I have been thru the ordeal with mine and I have the exact system you have so I can help you a lot.  If you email me I will share my phone number and we can talk directly.
N6AJR
« Reply #17 on: October 23, 2011, 03:21:27 PM »
To mount your antenna, I say look down....  What I mean is slide under the front end of your vehicle and bolt or weld a plate to the frame under the front end.  say some steel or aluninumuninumin plate a quarter inch thick, 2 inches wide and  long enough to stick out the front of the vehicle far enough to mount the antenna on.  If you put it at the corner at a 45 degree angle, drivers side,  it will be  out of the way of the hood, you can see it well, and folks walking down the street won't  be able to twang the antenna , just because. this can also be done at thee rear of the vehicle. when you sell the truck, just cut it off or unbolt it.
