Author Topic: Setting up TMD-710 as a digipeater  (Read 3973 times)
M6GOM
« on: November 12, 2011, 04:58:22 PM »
Hi. I'm quite new to APRS and could do with a bit of help setting my Kenwood TMD-710 as a digipeater. I need to do it so that when it digipeats, it enters my station call in the path. I also need it to digipeat a station that has already been digipeated if possible as a friend and I in a remote area are trying to work out coverage and paths and he can get digipeated from another station sometimes. So far I think I've got it figured out mostly apart from a couple of entries.
I have menu 616: Digipeat (My Call) set to ON.
I have UIDIGI set to ON and the Alias to WIDE1-1
UITRACE. This is where I need help. Do I need it on and what alias do I want to be using? The Kenwood manual says to use WIDE_4 but websites say to use WIDE.
M6GOM
« Reply #1 on: November 12, 2011, 05:24:36 PM »
Not to worry, I've worked it out. I tried setting it to WIDE and its doing what it is supposed to.
W5LZ
« Reply #2 on: November 21, 2011, 04:19:03 AM »
'GOM',
If it's doing what you want it to do as you have it, leave it alone.  But, later, you might try 'WIDE2-1' just for grins.  See what the difference is, if it appears to be beneficial.  If so, then good.  If not, then change it back.
 - 'Doc
M6GOM
« Reply #3 on: November 23, 2011, 06:51:08 AM »
If I've read the manual correctly, putting WIDE in should do 1-1 and 2-1. What difference does 2-1 make or should it make?
W5LZ
« Reply #4 on: December 01, 2011, 06:42:26 AM »
Very basically, it will produce one more 'hop' for a digipeated signal.  No idea if that would be of any benefit in your situation, so that's why I said to "try it and see".
 - Paul
