"the fact it just is, the Hy Gain Hy Tower AV-18HT the best of the best check it out."
43' verticals are almost invisible compared with the costly tower-mounted Hy tower. AFAIK the only significant advantage of the Hytower is on 80 and it doesn't cover the whole band without a tuner. The 43 footers often require no concrete or guys, and work all the way up to six meters to some degree, including WARC, MARS and 60 meters.
My DXE 43 footer is fairly effective even on ten meters. I put up an inverted V at 40 feet to compare it to.
I'm guessing that many hams wouldn't need a construction permit with the thin 43 footers. If you want better performance on 80 and 160, use a base tuner.
